    Yeti 575 Rear Shock - Need Help
    Hello everyone - sorry if this post is a little confusing but I will try my best to describe my situation.
    I am went to order the new marzocchi roco air shock for my 575 from BlueSkyCycling and the guy taking my order asked me the following questions.
    - What eye to eye length I needed - I said the 200 mm
    - What stroke - I said 50 mm.
    ------ I think those two answers were correct***********
    But then he asked me for the bolt length and the washer thickness. He says he needs to tell Marzocchi this info to order the right shock. I have no idea what he is talking about or if I even need to find out this information.
    Is he right, do I need to figure this out? Or does anyone know this information? I called yeti and the were no help all they told me was the eye to eye and stroke.
    Thanks in advance and sorry if this is a repost (I am at work on dial up ) so it takes forever to search.
    sorry ** I ment to say that he wants to know the bolt diameter and length.
    Reputation: jet fixer's Avatar
    Feb 2006
    check the owners manual
    The owners manual has all the hardware listed in the back. I would look it up for you but if I'm wrong its my fault if you do it yourself then its yours.
    LINK: http://www.yeticycles.com/Support/Su...nersManual.pdf
    Adobo Lover
    Reputation: 95Stumpy's Avatar
    AZmountainkiller, did you ever get the roco bolted on your 575? Just curious!
    National Athletic Trainers' Association, www.nata.org
