Results 1 to 28 of 28
    AS-X spring rate
    I have a medium 2006 AS-X frame w/ FOX DHX 5.0 and stock 450 spring.
    I weight around 167.
    Yeti have a shock setup guide on their site with a spring rate table, according to this table the 450 spring is for 130-190 lbs riders.
    I get around 40-50 % SAG with this spring with full gear.
    should I change it to a 500 spring (with rider weight of 150-210 according to Yeti) ? won't the bike be too firm for my weight ?
    I haven't bottomed out, can I damage the shock if i'll continue riding with my spring until i'll replace it ?
    i still haven't replaced the spring, i don't know if i should get a 500 or a 550 spring.
    how can it be that the stock 450 spring is too low for my weight ?
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Did you adjust the spring preload?
    How much do you weigh in full gear?
    Yeti suggested a 550 spring to me but I and the guys at the LBS figured that a 600/2.55 would work for me. Happy so far.
    the preload is closed all the way, and i get around 50% sag even without gear.
    i weigh 76 kg.
    i replaced the spring to a 550 that was in my lbs without paying anything.
    sag seems to be okay (about 35% with preload fully opened), but the bike feels stiff (maybe im just not used to it).
    should i keep this spring or try to get a 500 spring ?
    Feb 2006
    this doesn't make sense.. it says I need a 400 spring.
    also some fox calculator I used said I need 450.
    does anyone have any idea what shall I do ?
    Reputation: dminor's Avatar
    Stick with the Yeti factory recommendations. They gear them for riders around 160# (plus or minus 10). 40-50% sag is what you want - - sounds like things are perfect. If you aren't bottoming, you are OK.
    I have the 04 frame with the 5th Element and I weigh about 170#. When I got it, I set it all EXACTLY to the factory default values and it has never given me any troubles at all.
    Yeti | RST | Hayes | SixSixOne | Royal Racing | Syncros | Twenty6 | Kenda | Bicycle Butler Spokane, WA
    thanks for the answer,
    I wasn't bottoming with the 450 spring, my "expert" friend which is a little bit heavier than me bottomed out on a test ride and closed the bottoming out almost all the way until i'll get a new spring.
    the 50% sag is too much, really hard to pedal.
    i'm pretty clueless with this spring thing.
    Reputation: Joules's Avatar
    I also don't see how you are getting that much sag. ASX uses a 2.5" travel damper, to get either 6.5 or 7.3" travel - that's either 2.6:1 or 2.9:1 ratio. 40% sag would be 450# at the spring with the 450# spring, 50% would be 562#. I'm sure someone will doublecheck my math, but it seems to me like you'd have to weigh well over 400 lbs with gear, and have all of your weight on the rear wheel, to get that much static compression. That's not to say the setup isn't too soft for you, but if you really are getting that much sag I'd suspect your spring is not indeed 450#. I'm an XC kind of guy so this is more of a question: is it possible a spring could crack or somthing (some explanitaion why he isn't getting spring rate). Only other explaination I could think of is the spring is actually lighter and is mis-labeled.
    edit: I just thought about it some more, my math is assuming the compression ratio is fairly constant i.e., 2.6" (or 2.9") of wheel movement equals 1" of spring compression. If the ASX uses a fairly extreme rising-rate linkage that could account for low forces witha lot of sag. still seems like a lot with that spring...
    How are you measuring sag anyway? I've yet to figure out a good way with coil shocks.
    Im estimating the SAG by looking at it, not very accurate but it gives you the idea.
    The idea of a mislabled spring crossed my mind..
    with the current 550 spring I get 30-35 % sag... so with a 450 it cant be 35%...
    I sent emails to both yeti and fox, yeti stick to their 450 recommendation, fox had a more detailed reply saying 450 is recommanded for the 6.5" travel and 500 for the 7.3"
    (im using the 7.3").
    You need to measure things rather than eyeballing to be sure. BTW, I looked at the DHx setup and, contrasting it with my 5th Element, I stand corrected. Looks like my 5th could take more sag (30-50 for DH use), whereas your DHX calls for 35 max it looks like.
    Measuring sag is easy. Measure the eye-to-eye unloaded. Then sit on it both feet off the ground (lean against a wall - lightly) and measure eye-to-eye. Divide the difference (sag) by the shock's stroke and viola! (or use the numbers on your setup guide, page 3).
    According to the chart, too, a 550# spring is way off the scale - no way you should need that much spring for your weight. This is an ASX, not an XC racer. Let it sag. Plant your butt on the saddle and spin to climb.
    definitely measure it as carefully as you can.... 30% sag is good..
    I am 210 and i had to put a 650lb spring on my asx to get it right.
    I have a 2003 asx which has a shorter shock on it, so it needs a sligtly stiffer spring. I converted mine to a DHX though.
    I like having a stiffer spring on my ASX.
    Also those spring caculators usually assume linear spring rates.... the ASX is an extremely high ramping spring design. Yeti's setup guide for the ASX recommends maximum volume and minimum pressure... I have found these settings to be great. this minimizes the "SPV" or "pro pedal" affects. Also i would say the DHX on the ASX works best with pro pedal off if you are going downhill and max propedal when climbing.... Fox should make a pro pedal lever for the DHX in my opinion.
    The ASX design pedals incredibly well without any stable platform.... i think Krispy at go-ride is even using a VANRC on his ASX.
    I am a yeti addict, 8 in all:
    Currently built:
    ASR-SL, 575, DH9, Road Project, FRO
    Currently in Pieces:
    ASX, Lawill-6,ARC
    so what do you suggest me to do? keep the 550# spring with the 30+% sag and stiff feeling atleast when static compressing it by sitting down or try to get a 500# spring?
    i just don't understand how come Yeti's recommendation for a spring is wrong.
    Feb 2005
    Quote Originally Posted by bsphere
    I weight around 167# ~76kg
    Hi bsphere,
    We seem to be in the same boat: I don't know how much I weight with all the gear on, but considering that butt-naked I'm circa 76kg as well, my riding weight must be >180lbs ~ 80+kg (2-litre bladder alone is 2kg). I'm riding 2005 AS-X medium on the same shock/spring combo, and I also feel it's way too soft: due to ~50% sag, I tend to hit roots and rocks with my pedals a lot. The only difference is that I do bottom it out on harsh landings.
    I asked at my LBS whether I should go to 500#, but they said that 50# increase wouldn't make sufficient difference, and that I should increase by 100# or to 550#, which I'm about to order.
    Anyone else on AS-X @ same weight out there? -- what spring rate do you run?
    Cheers,
    -Tomasz
    its nice to hear that im not the only weird one in this situation.
    I emailed both Yeti and FOX.
    Yeti says 450 and that's it.
    FOX said 450 for 6.5" and 500 for 7.3", my LBS too said that a 50# difference is nothing.
    currently I have a 550# spring that I replaced with my 450# for free. at static compression (sitting on the bike) it feels a little bit stiff (maybe im just not used to it), but the sag is about 30%+ which is fine.
    I haven't ridden it in the trails with the new spring yet so I have no further info.
    Reputation: desmo's Avatar
    AS-X Spring
    My ASX in the 7.1" travel setting is a 500lb spring, my weight 175Lbs, suited up 185lbs. The spring rate is perfect.
    Feb 2005
    Quote Originally Posted by desmo
    Thanks Desmo!
    185lbs = 84kg; suspect with full gear I might be closer to 190lbs, and believe it's better to be at the "low end" of a spring (less preload), so this seems to confirm that 550lbs should be just about right for me
    Feb 2005
    Did you have a chance to test it? -- how does it feel on a trail and doing jumps / drops?
    it feels just fine, maybe it's a little bit stiff and i need 500, but i got a good sag.
    i dont know if it's worth the time and $$$ to replace the 550 to a 500 just to check.
    Feb 2005
    Guess we get used to what we ride, so possibly after riding too soft a spring, the optimal one may feel too stiff by comparison (?) -- bottoming-out would be a good practical test: if it never happens, then the spring is too stiff. I reckon I will manage to bottom it out every now and then.
    Feb 2005
    have you stuck with your 550# ?
    Guess what, bsphere: I'm still on my stock 450# spring... (a supplier was out of stock when I had an opportunity to buy) ...but at least I can ask for your "field-test" feedback (?!)
    Cheers,
    -Tomasz
    i'm pretty happy with the 550# spring.
    I don't get to ride much because of exams and the weather, but it seems to be just fine, i don't bottom it and its not too stiff..
    My 2005 medium, asx came with a 450lb spring which always felt soft. At 180lbs, i was 35% into my sag w/out gear. Replaced with a 550lb spring and am much happier with the ride of the bike.
    Also, fox springs are known to have a standard error in rating of up to 25%. Think about that one. A 450lb spring could be anywhere between 340lbs-560lbs... just fyi.
    psphere- call me at 253-970-4594 if you still have any setup questions,
    Reputation: ryan_daugherty's Avatar
    Adam (NWfreeride) is 100% right on this one. When we first bought our as-x's we were a bit confused about the over sag. I bought a super fat kid spring 700lb, for a 200lb rider and exchanged it for my 500lb spring.. it brought my sag from about 50% to 35%. The bike felt so much better, in its pedaling, descending and landings off of jumps and drops.
    Mar 2006
    500 lbs works for me
    I come in at 220 lbs with gear and ride a 500 lbs spring, which with 3 turns pre-load sets me up nicely at 37% sag. I can't believe that somebody even with my weight can get a decent sag and and full travel with a 700 lbs spring. Are the shock strokes different depending on the vintage of the bike? Mine is a '06 with a 2.5" stroke. I established my spring rate by using the spring calculator that an old friend of mine in Austria has put together "http://www.igorion.com/_coilspring/" and it has been spot on (he is quite a suspension whiz and regular contributor on these matters in different forums). I guess this is all personal preference, but I feel that for downhill and technical single trail riding (my biggest drops are probably around 6-7') a softer suspension with increased bottom out resistance just works better. It is just amazing how the AS-X flies trough some of the gnarly rock gardens. You just point the bike and let gravity take care of the rest. I learned to set up my suspension on all of my bikes soft enough that I use 100% of the travel on my ride and only bottom out maybe once or twice on the higher drops or because I missed the transition. Initially I was riding my suspension way to stiff and wasn't really using all the travel I had paid for.
    Nov 2006
    not being patronising but i know alot of people who mess there sag levels up by a simple mistake.....to read we push the rubber stopper thingy to top of shock sit on bike gently then stand up in attack position gently.get off bike carfully without compressing shock anymore. now this is where some people mess up......to measure sag you measure from top of shock to top of rubber thing.some people measure from top of shock to bottom of rubber thing which will change a proper sag reading of 30 percent to an inproper reading of 50 percent. im 180 lb use a 450 spring and get a 30% reading but if measue wrong bit it reads that im getting a 50% sag.
    I dont think Fox is too far off on their ratings.... one big differance i did notice though is that Fox springs are a lot lighter than some others, I compared a manipoo spring to a fox spring for the same length, rate, and diameters. The fox spring had thinner wire and fewer turns, making is the same spring rate but a much lighter spring. This puts higher stress on the fox spring, but as long as it doesnt fail or yield, that means that the fox spring was better engineered. I have never seen a bike spring fail either.
    I run a 650lb spring on my asx, definitely had to over rate the spring for me to be happy with it. I havent tuned too much, but there is an arguement that a softer spring with more compression damping, and some more ramp up in the bottom out reservoir will give you more usable travel, allowing you to mob deeper obstacles with more control.
    Currently built:
    ASX, Lawill-6,ARC
