The axle length usually depends of the cranks you use, for instance the octalink LX use a 121mm axle, so it would really depend on the crankarm/axle combination you plan on using.
It all depends on crank selection. Some cranks really offset their chainrings inward (narrower chainline) and others kick them outward (bad chainline). The problem I see with today's outboard bearing bottom bracket set ups is that the chainlines are horrible! Don't even think about running the middle chainring/large cog as you'll be droppin' chains often. I'm currently using a 118mm length spindle ISIS with Raceface Turbine cranks on one of my 575's and notice my chainline isn't great but have no issues with shifting or chain droppage. So.... 118mm is doable, you just need the right crankset to go with it.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
