Results 1 to 6 of 6
    what BB for e13 drs on asx?
    does a raceface evolve DH bottom bracket work with an e13 drs via e-type?
    what othet BB's do also fit?
    Stray Bullet
    Reputation: Nagaredama's Avatar
    When I called Yeti they said to buy a 73/73E x 118 (spindle). E-13 also told me the same thing.
    so the evolve dh fits?
    Phil from San Diego
    Reputation: Prexus2005's Avatar
    Mar 2005
    I'm using a Shimano Hone crankset w/ integrated BB... I forget what the dementions are. Will that work with the e-13 DRS system? I think it's E-type compatible by removing one of the spacers on the drive side..
    Phil.
    Reputation: munga's Avatar
    Correct!
    The e13 DRS is the same width as an E-type front drailleur. All shimano/FSA?Raceface integrated type sets will work. I previously used an octalink 73 shell BB. The same one i used without the DRS.
    Hope that helps
    Mike
    No More Signatures
    ok, i just installed racaface evolve dh, and it works perfectly.
    thanx for info
