Results 1 to 6 of 6
    May 2010
    volume spacer kit
    Who is using a volume spacer in their RP23 or CTD shock and which size spacer are you using? I have had my SB66 for one year and haven't opened up the CTD shock yet for service, but I'm assuming there is no spacer installed. Can anyone confirm that the CTD's come with no spacer's from the factory?
    Chilling out
    Reputation: bear's Avatar
    On my large SB95, me being about 210 riding weight, I use the smallest volume spacer in the rp23.
    I tried the medium spacer but the ramp-up was more than I wanted, small worked well. Shock at 195 psi.
    The shock on the SB95 doesn't have as much stroke as that on the sb66 though, I'd guess on an sb66 I'd want the medium spacer.
    Reputation: client_9's Avatar
    "RP" spacer kit compatible w/ CTD shock?
    Is THIS RP spacer kit compatible w/ my newer CTD Float shock?
    thanks!
    Chilling out
    That's what I used on the RP23 non-CTD that came on my '12 SB95, dunno if the '13 CTD has changed anything with the air can and volume spacers.
    One call to Fox on Monday would answer that question though.
    I opened up my '13 Float CTD shock and found the .4 spacer already in there.
    Not sure if previous owner did this or it came from Yeti this way.
    Reputation: mtnbiketodd's Avatar
    I opened my '13 CTD this weekend on my SB66 and it had a spacer in there which I had no idea what it was until this thread started up. Mine came from Yeti which this spacer.
  1. Fox float volume spacer kit
    By trap121 in forum Shocks and Suspension
    Last Post: 02-23-2015, 04:51 AM
  2. Should I consider a Fox Air Volume Spacer? Float CTD
    By yboc in forum Shocks and Suspension
    Last Post: 04-20-2013, 04:41 PM
  3. Fox volume spacer kit & DRCV
    By Ominous in forum Shocks and Suspension
    Last Post: 10-07-2012, 03:48 PM
  4. Fox Float Air-Volume Spacer Kit
    By mountainbiker24 in forum Shocks and Suspension
    Last Post: 09-09-2012, 06:01 PM
  5. fox float volume spacer kit ?
    By keen in forum Shocks and Suspension
    Last Post: 11-21-2011, 09:26 AM
