Results 1 to 6 of 6
    Reputation: miggy's Avatar
    Nov 2008
    tapered stearer in a non tapered 575
    can it be done? with cane creek or hope lower cups? if so any pictures or info on geometry?
    Rolling & Tumbling
    Nov 2008
    Quote Originally Posted by miggy View Post
    I guess it can't be done 😥
    Rolling & Tumbling
    Sure it can , you press out the taper steerer tube and machine a spacer and install a straight steerer in and there you go .
    I would always make the straight steerer tube I needed , but now you can buy the tube if you can not machine one .
    I have done many of these for guys .
    Reputation: drbelleville's Avatar
    See if this helps any - Cane Creek has been doing some work on this. Is your Headtube 44mm?
    New headset allows use of tapered steerers in some 1-1/8in head tubes - BikeRadar
    40-Series
    Ride Driven
    No need to modify your fork. almost all headset companies make a head set that will work. here are a couple from Cane Creek and Chris King.
    2011-2012
    Cane creek- EC34 Top w/ EC49 CONVERSION BOTTOM
    Chris king- 34/49 with DEVO base plate
    2013-2014
    Cane creek- TAPERED CONVERSION ZS44|ZS56/30
    Chris king- 44/56 with DEVO base plate
    Ride Driven
    sorry read that backwards. No you can not put a tapered fork on a 575 that has a straight 1 1/8 head tube.
    Quote Originally Posted by YetiDemo View Post
    2011-2012
    2013-2014
  1. Non-tapered Niner carbon fork on tapered RDO frame.
    By unstuckpilgrim in forum Niner Bikes
    Last Post: 08-14-2012, 06:59 PM
  2. Replies: 4
    Last Post: 05-11-2012, 01:15 PM
  3. Magura Tapered Fork in Spec. Tapered Head Tube
    By phlegm in forum Shocks and Suspension
    Last Post: 05-09-2012, 05:27 AM
  4. Replies: 4
    Last Post: 10-24-2011, 12:50 PM
  5. Replies: 10
    Last Post: 03-16-2011, 12:27 PM
