Results 1 to 6 of 6
    Reputation: flipnidaho's Avatar
    Talas and Revelation clearance for Kenda BG or Nev 2.5's
    I'm about to pull the trigger on some Kenda BG 2.35's, 2.5's and Nev 2.35's and 2.5's (it's going on a few different bikes). Will I have any clearance issues on the 575 front and rear? I'm currently running Mutano 2.4's and Michelin AM 2.25's.
    surly inbred
    Reputation: TroutBum's Avatar
    You'll be fine on the rear and w/the Fox with 2.5's ...can't speak to the Rock Shox.
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by Harp
    You think the 575 rear will handle 2.5s? My 2.1 Nevegals fill it up pretty well, I am surprised to hear someone say that it would take 2 sizes bigger.
    Hi!!!
    Reputation: BelaySlave's Avatar
    This is from the Yeti site FAQ....
    The 575 can accept up to a 2.5” rear tire.
    Idaho Biking Yahoo! Group
    Support these shops: www.CustomMtnCycles.com & Reed's Cycle
    But we all know that "2.5" is a very subject measurement that varies widely between tires.
    The Nevegal is a huge 2.1, compared to the Schwalbe Big Jim 2.25 that I have that is smaller than the Nevegal. Maybe the difference in size between the 2.1 & 2.5 isn't that big in the Nevegals, I've only seen the 2.35 (which is noticeably bigger than the 2.1).
    I guess someone will just have to post up some tire clearance shots....
    surly inbred
    FWIW... I've run 2.5 IRC Trailbears with no issues.
