Results 1 to 10 of 10
    2006 sswc RockStar
    super light ASR-SL builds
    anyone got anything near the magic 20lbs mark?
    mutaullyassuredsuffering
    Reputation: used2Bhard's Avatar
    Dec 2005
    Tires
    With silly tires like the 310's or Crows, mine will be in the 20.5 lb range. I typically run something with traction that won't slice instead, so I race it in the high 21's.
    Free will is an illusion, people will always choose the perceived path of greatest pleasure.
    Quote Originally Posted by used2Bhard
    Whats your build look like? I am thinking about building an AS-R myself and looking for ideas.
    ASR-SL Carbon 2006 Build
    I got to about 21 lbs here, and w/ Maxxis MaxxLites I get about 20.5. In this case, it is silly that it is so light, since it is sprung weight, and the scale does not show how little of it actually effects riding. Build list is:
    Fork: Rock Shox SID WorldCup Carbon 100mm/PushLoc
    Headset: Chris King NoThreadSet 1-1/8" Red
    Stem: Syntace F99 Ti
    Bars: RaceFace NEXT SL Carbon 1.5
    Shifters: SRAM X-0 Triggers
    Levers: Hope MonoPro w/ Red Levers and Caps
    Cable: JagWire GoldMedal Sterling J3 w/PurelyCustom Red Endcaps
    Brake Line: GoodRidge Stainless Braided w/ Hope Ti hardware
    Wheels: Spinergy Xyclone Race Disc
    Tires: Continental XC Kevlar or Maxxis Maxxlite 310
    Tubes: Maxxis FlyWeight
    Cranks: Adventure Components Cobra Carbon
    Bottom Bracket: Crank Brothers Cobalt Ti Ceramic
    Pedals: Crank Brothers Eggbeater SL
    Chainrings: StrongLight Dupont Zycral
    Chain: KNC X9-SL
    FD: Shimano XTR Clamp On ('08)
    RD: SRAM X-0 Long Cage ('07) w/ RSP Composites Cage and Ceramic Pulleys
    Rotors: Hope Floating Red
    Calipers: Hope MonoMiniPro w/ Red Hardware
    Seat: Selle San Marco Carbon Monocoque Superleggera Titanium
    Seatpost: Syntace P6
    Clamp: Hope w/ Ti Bolt Red
    Bolts: PurelyCustom: Red Bolt Covers, Red Valve Stems. TastyNuts/ProBoltUK: Brake and Stem Bolt Kits, SRP: Titanium Crank Bolts, HBC: Ti Rotor Bolts, Token Ultralight Alloy Bolts
    Dec 2005
    Build
    I ride the bike in many trims depending on what I am doing with it (Endurance, XC, fun). The light setup is around 20.5 with my computer, bottle cage, chainstay protector (ready to ride!):
    Frame = '08 ASR_SLC (golden made) M (4.81lb)
    Fork = '08 SID Team with pushlock
    Wheels = Stans ZTR RACE (1207g) (I also have Olympics/240/revo's (1355g) and 355/240/supercomp's (1540g) for training)
    Headset = King (changing to CB Cobalt soon)
    Rotors = Stans alum 160 front, 140 rear (I also run the hope floating rotors if it's gonna be wet and for training)
    Crank = XTR 970
    Cassette = XTR970
    Shifters = XTR 970 Triggers (ti bolts)
    Brakes = Juicy Ultimates (ti bolts)
    Der's = XTR 970
    Seat = Spec toupe for XC, Phenom for endurance
    Post = Syntace P6 (chopped to length)
    Stem = Ritchey WCS 4-AXIS (ti bolts)
    Bars = Syntace Vector Low Riser Carbon
    Grips = Titec Pork Rinds or Ritchey WCS Foam
    Skewers = DTSwiss Ratchet TI
    Cage = Torelli Carbon
    Computer = VDO 1.0+ wireless
    Pedals = Eggbeater 4-Ti
    Photo show the bike as I train on it (355 wheels, hope rotors, heavy tubeless rubber, 1-ti pedals, seatbag)
    Crank = XTR 970
    Cassette = XTR970
    Der's = XTR 970
    Sweet build. Just curious, you say that your '08 ASR_SLC is made in Golden. Your frame looks different than the 08's shown on Yeti's site. They only show an ASR in Turq/Black/White, and the Yeti lettering is on the side of the downtube. Am I missing something? And what is the "SLC" ? I don't see an ASR SL listed on Yeti's site.
    Dec 2005
    08
    Quote Originally Posted by GotMojo?
    Yeti took the last remaining golden made frames and painted them with a special color scheme. Basically they just took the scheme of my '07 (below) and put white instead of the brushed aluminum.
    The SLC refers to the full carbon rear end. If you look at the red bike above, you will see that in '06 the chainstays were carbon, but the seatstays were aluminum with the carbon plug. Going from the SL to the SLC shaved around 100g and made the rear end stiffer and more active, as the stay flexes better than the carbon plug did on it's own.
    For '08 they dropped the 'c" in asr-slc to avoid confusion with the ASR-C. Really they are all ASR-SLC's now as it's the same stay on both the alloy and carbon version. The cabon dogbone is the only suspension change on the ASR-C. It adds another level of stiffness to the rear end.(I had and ASR-C for half of the season)
    I'm the purveyor of worthless knowledge when it comes to ASR-Sl's...
    '08
    '07
    '06
    ASR-C
    Real Estate Guru
    Reputation: RichieRich's Avatar
    Do you not have a carbon frame anymore??
    If not, what did you not like about it?
    Dec 2005
    Economics
    Quote Originally Posted by RichieRich
    Long sorted tale...
    It was just an economic decision. I got the white ASR frame in the spring thinking my ASR-C frame wouldn't show up. I was lucky and ended up gettting bike #20... in Feb/March. When my job went to heck in the middle of the summer and I lost alot of pay, I sold the ASR-C and just raced an ARC for a while (I won the ARC in a raffle) . After realizing (for the second time) that a HT wasn't the ticket for me. I swapped everything over to the ASR-SLC frame and rode it for my endurance races in the fall.
    Overall, I am perfectly happy with the Alloy, and don't intend to go back to a carbon. The carbon was a better XC race bike, but I am going to be doing more ultra endurance racing from here on out. The alloy bike is less punishing on my body and is more durable/easliy replacable if I crash it in the middle of nowhere. My ego will survive not having the bigger/better/fastest/newer for now.
    My ASR-C
    2008(?) ASR-Carbon Medium frame w/RP23 shock 2160g (4 1/4 lbs? More like 4 3/4 lbs)
    Shimano crank bearings/bearing holders/plastic spacers/plastic center cover (included in frame above)
    2007 Lefty Speed Carbon SL shock 1250g
    Custom made CF/Al 1 1/8 to Lefty steerer adapter 125g
    XTR M975 disc brake levers and calipers (tuned)
    Scrub Components 160mm front rotor (56g)
    Scrub Components 140mm rear rotor (41g) (not in pictures)
    Syntace F99 Ti bolt 120mm stem
    Schmolke SL 560mm flat bar (97g)
    KCNC BE1 bar ends (48g)
    ESI race silicone grips
    Sram twist X0 shifters w/al. clamp bolts
    Alligator I link shifter housings
    PowerCordz shifter cables
    Crank Brothers Cobalt SL headset (65g)
    Tune Gum Gum headset starnut with carbon cap and al bolt
    5mm plastic steerer spacer
    XTR M970 175mm crank arms (335g)
    Extralite Octaramp 44 and 30t chainrings (2x9) (86g)
    Aluminum chainring bolts/spacers, etc...
    EggBeaters 2Ti with Ti short axles (173g)
    Campagnolo Record Ti Compact braze on FD
    Parlee 34.9 carbon FD adapter/clamp
    KMC X10SL Gold chain 106 links (228g)
    '08 Sram X0 medium cage RD with carbon pulleys and carbon inner cage plate (173g)
    Nino Ti 11-34 SL cassette (178g)
    Tune SpeedNeedle Alcantra seat (85g)
    Tuned (mildly) Yeti ASR-C seat clamp assembly (195g - ouch! I`m gonna fix this one)
    No Tubes ZTR Race 7000 Lefty front wheel including Lefty axle bolt and extraction cap (570g)
    DT190 rear hub/DT tuned centerlock to IS disc adapter/DT Revolution 2.0-1.7-2.0 spokes/al nipples/ZTR Olympic rear rim 32hole (722g)
    Yellow tape and Olympic valve stems in both front and rear wheels
    Tune Skyline rear MTB bolt on skewer (13g)
    Continental SpeedKing Supersonic 2.3 front tire (456g)
    Continental RaceKing World Cup 2.2 rear tire (480g)
    No Tubes sealant in both tires (3-4 ounces)
    Currently 19.3 lbs. Shooting for 18.5 lbs. Coming soon!
