Results 1 to 5 of 5
    Reputation: Andrew8404's Avatar
    Setting Sag on Fork and Shock
    So my 2011 Yeti 575 is the first mountain bike that i've had with a legit suspension and I'm having trouble figuring out the right amount of sag on the fork and shock. I'm 6'1 and weigh approx 200 pounds. I initially set the fork at 40psi which felt amazing but was probably too plush and the shock at 210. Everybody said those where way too low so now i'm at 75psi up front and 240 on the rear. I guess I'm just wondering what numbers do you guys run at and find best?
    Lucky...
    On my 07 I run pressure equal to my riding weight in the shock and half my weight in the fork (Fox Float RLC). Works well.
    Feb 2005
    Nody weight with gear on is a good starting point on the rear shock. For reference on the front with my Talas 36 I run 60 PSI with about 7 clicks of low speed compression.
    Reputation: mtb_tico's Avatar
    Have a look through You-tube tutorials. In 2 minutes, you can learn a lot!
    A good sag on you Fork about 3 cm or 1.25 inches. Increase sag slightly if you're in more technical terrain. Watch this: Competitive Cyclist Guide to Fox 32 RLC Fork Set Up Shock Set Up - YouTube
    WAtch this too...
    Technical Tuesday - Setting Your Sag - Pinkbike.com
    Also have a look on the Fox shoxs website
    PL
    Jan 2011
    I'm using 25% on my shock 5 clicks (fast) rebound, 30% sag on front 14 clicks (fast) rebound, Compression 5 clicks clockwise (from full counter) Lock out 1 click from full counter...
  1. Setting Sag of Fork and Shock
    By horriefic in forum Shocks and Suspension
    Last Post: 01-04-2011, 02:09 PM
  2. Enduro Comp.: Setting the fork and shock
    By bavka in forum Specialized
    Last Post: 07-03-2009, 05:36 AM
  3. Setting Up Fox Shock and Fork
    By fifafu in forum Shocks and Suspension
    Last Post: 03-17-2007, 11:08 AM
  4. Help with setting up fork and rear shock
    By 3lite0hbik3r in forum Beginner's Corner
    Last Post: 11-21-2006, 01:26 PM
  5. Help setting up my new geminis Fork/Shock
    By gemini2000 in forum Cannondale
    Last Post: 04-19-2005, 12:06 PM
