    EXW
    EXW is offline
    May 2013
    SB95c Seatpost Torque Setting
    Does anyone know the torque spec for an SB95c's seat post collar? I've looked in the documentation, Yeti site, and a general Google search and can't seem to find it.
    Thank
    Aug 2013
    I emailed this question to Yeti service and got message from Matt Fisher:
    The max torque on the seat post QR or bolt should be 6nm. But you can stop once the post does not slip if that high torque is not necessary. If you get to 6nm torque and the post still slips then there is something else happening that needs to be worked out.
    EXW
    EXW is offline
    May 2013
    b0r1sKa, thanks for for getting the answer. I also sent them the question but haven't heard back yet so I'm guessing it got lost.
    In any case, thanks. Using a 5nm, it gets plenty tight before the torque limiter kicks in. Good to know I'm within the proper range.
    Reputation: Just J's Avatar
    Feb 2005
    I run a Thomson seatpost clamp on mine, just set to their recommended 2.8nm and you're good to go. It's been faultless on a few bikes over the past couple of years and it looks factory which is the main thing!
  1. 2012 Element 950 main pivot torque setting ??
    By ccaddy in forum Rocky Mountain
    Last Post: 03-09-2014, 08:59 AM
  2. Replies: 0
    Last Post: 01-26-2014, 04:13 PM
  3. Torque Setting for Alligator Wind-Cutter Rotors?
    By dshoe70 in forum Brake Time
    Last Post: 06-05-2013, 03:07 AM
  4. Carbon parts: Torque setting
    By gfs69 in forum 29er Components
    Last Post: 10-23-2012, 02:31 AM
  5. Replies: 2
    Last Post: 01-10-2012, 03:53 PM
