Results 1 to 3 of 3
    SB95C Internal Routing Problem
    Hi. I have a big problem with my gear cable routing on my SB95C.
    The sleeve that was threaded through the swingarm has come out - I managed to thread the inner through it ok, but then the outer wouldn't go over the top of it and come out the bottom - it was getting caught on something and wouldn't go. Anyway, the outcome is, I eventually, after much messing about, managed to get the inner cable that was routed through to fall out, and now I'm completely stuck.
    I can't get either of the 2 cables or the sleeve to route through it now. I'm getting incredibly frustrated with it.
    How can I fix this? How does the sleeve get routed through their in the first place?
    Reputation: client_9's Avatar
    I had a bike with internal routing and no guide sleeve.
    What I would do is first run a straightened wire coat hanger thru the frame.
    Then shove the end of the wire hanger into the cable housing and pull it through slowly.
    * You will need to cut off the end of the housing as the coat hanger compromises the internal liner.
    Thanks for the help. I managed it in the end, by reverse threading the plastic sleeve through the swingarm and with a great deal of frustration, I managed to get it out with tweezers.
    Even then, getting the outer back through the bottom hole was very difficult. A very frustating and annoying few hours.
  1. Internal routing for 14 Anthem 27.5
    By Van G in forum Giant
    Last Post: 10-18-2013, 11:27 AM
  2. SB95c Rear Brake Hose Routing?
    By Just J in forum Yeti
    Last Post: 07-12-2013, 04:56 PM
  3. Internal Cable Routing?
    By kfb66 in forum Niner Bikes
    Last Post: 01-03-2013, 02:53 PM
  4. Internal Cable Routing
    By Phishin Paul in forum Ventana
    Last Post: 09-22-2012, 03:20 PM
  5. Rohloff w/ internal routing??
    By smdubovsky in forum Frame Building
    Last Post: 01-01-2011, 09:46 PM
