Results 1 to 3 of 3
    Aug 2013
    SB95 Creaking at pivot points
    Started out with ocassional ticking but now full on creaking around pivot points. Already ruled out the bb and crank. Anyways, getting ready to open her up.
    For those that have done this already, any tips or tricks, areas which need lube or not to lube.
    Thanks in advance.
    Aug 2013
    Update: Just wiped off all the old grease and dirt and relubed. After putting everything back together, creak seems to be gone for now. Always fun chasing creaks on a bike!!!
    Reputation: mtnbiketodd's Avatar
    kickhorse,
    I had the same problem on my SB66C and I did the same pull it all apart, clean, re-lube and put back together. Problem solved!
    Sounds like your is solved for a ride or 2 as well
  1. How to clean pivot points
    By KevinGT in forum Yeti
    Last Post: 06-13-2013, 08:24 AM
  2. El Guapo V.2 Pivot points
    By mvt20ten in forum Titus
    Last Post: 08-11-2012, 08:38 AM
  3. FSR Pivot Points
    By stumpy6 in forum Specialized
    Last Post: 07-05-2012, 02:36 PM
  4. maestro pivot points squeaky/creaking
    By absoluteczech in forum Giant
    Last Post: 06-22-2012, 05:33 PM
  5. Lube protocol for rear triangle pivot points?
    By C83L5oD in forum Beginner's Corner
    Last Post: 03-25-2011, 04:30 PM
