Results 1 to 8 of 8
    SB95 Carbon switch eccentric
    I was chasing down a creak in my SB95 carbon this morning and took the switch eccentric a part. I was surprised to find it would not rotate by hand before I pulled it out. I cleaned everything then lightly greased it and re assembled it. I still will not rotate by hand. any one who has taken one apart is this the way yours is?
    thanks.
    Chilling out
    Reputation: bear's Avatar
    I have rebuilt mine (last winter) and found that the non-drive side bushing is tight, but that I can *with force* move the eccentric.
    Moving the system with no-shock installed but by way of the rear triangle didn't seem to feel like there was any notable resistance to me, I could not decide if it was more or less than bearings would be.
    I can't decide if I wish Yeti had spec'd that side with bearings also, or the drive-side with a bushing. Tough call. It's not like there's a bunch of rotation there, so why did they use one style on NDS and one style on DS?
    Reputation: bpnic's Avatar
    Aug 2005
    I had the same with mine in my 66 when I rebuilt it last year. Bearings tight and notchy feeling, but moved easily when I cycled swingarm. I'll rebuild the 95 this Winter.
    Attached Thumbnails Attached Thumbnails SB95 Carbon switch eccentric-photo0776.jpg
    I'd hit it, but I bruise like a peach.
    Quote Originally Posted by bear View Post
    I was also surprised when I had mine apart and found the bushing / bearing set up.
    From an engineering standpoint the wide tight tolerance bushing has more contact surface area along the cross section and will keep that pivot point tight and ridged , while the bearing on the drive side can withstand the driving power forces loaded into it
    better .
    If my bushing ever had a problem I was going to remove it and machine the left side out and add a Torrington bearing , but after analyzing and finding the wide Torrington bearing that I would need to equal the surface area ( and still could not equal the tight tolerance ) I actually would just make a new bushing and fit it up tight and run it .
    After studying it , thinking I could better it , I was misleading myself and the Yeti design is actually very solid .
    Chilling out
    Man, I don't *even* know what a Torrington bearing is.
    But I'm glad that in the end you like the Yeti design, makes me happier. :^)
    Reputation: Colin+M's Avatar
    Quote Originally Posted by kelstr View Post
    better .
    Yeah, what he said. Mine's badass regardless of whatever engineering mumbo jumbo they used
    I guess mine is normal. thanks
    Quote Originally Posted by wilbcol View Post
    Yes it is , you just want to keep it really clean and packed with grease so its will slide smoothly with the rear section on it , but you do not want it loose at all .
  1. SB95 Switch movement all one way?
    By stejam in forum Yeti
    Last Post: 08-15-2013, 07:37 PM
  2. SB95 Carbon front derailleur
    By wilbcol7 in forum Yeti
    Last Post: 08-09-2013, 09:30 AM
  3. SB95 carbon rear brake creek
    By wilbcol in forum Yeti
    Last Post: 07-13-2013, 06:28 PM
  4. Specialized FSR Epic Carbon or Yeti SB95
    By DieselvRR in forum 29er Bikes
    Last Post: 06-11-2013, 07:06 PM
  5. SB95 Carbon Spotted!
    By banks in forum Yeti
    Last Post: 04-15-2013, 12:09 PM
