Results 1 to 8 of 8
    Reputation: wilbcol7's Avatar
    Oct 2011
    SB95 Carbon front derailleur
    Hey folks just got my SB95 carbon frame today and have started the build. Yeti sent three bolts in different lengths that appear to be for attaching the front derailleur. I am installing a Shimano XT. Does anyone know which length bolts should I use in which hole? Thanks!!
    Sent from my Xoom using Tapatalk 2
    Reputation: Sasquatch29's Avatar
    Jan 2013
    Quote Originally Posted by wilbcol7 View Post
    The bolt that fully penetrates the frame threads without sticking out too far (it will rub on the suspension stroke if it's too long). You have to test fit your derailleur to make sure it's just the right size. Dont over torque it...40 lb/in shoud be good.
    Oct 2011
    Re: SB95 Carbon front derailleur
    Which derailleur type?
    Hey,
    I am just ordering this frame now. Which type of XT derailleur are you using? Is it a direct mount? Thanks.
    Chilling out
    Reputation: bear's Avatar
    Quote Originally Posted by Canuckistani View Post
    Hey,
    E-type direct mount.
    Also known as SRAM S3.
    Reputation: bike21's Avatar
    Feb 2006
    Bottom pull right?
    Chilling out
    yes, bottom pull.
    many late model front-d go both ways though.
    the 95a has two cable fixing points, one for shimano and one for sram, be sure to puck the one that gives you the most direct cable action.
    Feb 2006
    Excellent, thanks for the info!
  1. Mach 5.7 Carbon Front Derailleur Issue
    By Isildur in forum Pivot Cycles
    Last Post: 10-19-2012, 08:55 PM
  2. Mach 5.7 carbon 3x9 front derailleur
    By PeterG in forum Pivot Cycles
    Last Post: 12-03-2011, 05:55 AM
  3. Which front-derailleur for 2x9 scalpel carbon
    By de Ron in forum Cannondale
    Last Post: 06-07-2011, 07:46 AM
  4. X Carbon 2X10 front derailleur issue
    By Bikerbob.com in forum Titus
    Last Post: 02-28-2011, 04:34 PM
  5. Front Derailleur Size Scott 29er Carbon?
    By epicracer5 in forum 29er Bikes
    Last Post: 02-23-2011, 08:05 PM
