Results 1 to 2 of 2
    SB66C ISCG/BB mounting
    I built up a SB66c recently and has a question about the iscg tabs.
    I'm using a 2x10 crank with no guide and a clutch der - do I need to run a bb spacer between the shell and bb cup if I'm not using the ISCG adapter? My chain line is a bit off and i think it may be the culprit.
    undercover brother
    Reputation: tangaroo's Avatar
    Quote Originally Posted by mtb-ripper View Post
    I'm building up an SB66c frame and has a question about the iscg tabs.
    Yes. The iscg adapter takes up the space for the spacer. Without the adapter and with just the "blank" you will need one spacer to make it 73mm.
  1. My SB66c came out fine.
    By smellurfingers in forum Yeti
    Last Post: 02-01-2013, 01:18 PM
  2. Anyone gone SB66a to SB66c ?
    By GlennW in forum Yeti
    Last Post: 11-30-2012, 12:05 AM
  3. ISCG old and ISCG 05 interchangeable?
    By zblee in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-19-2012, 02:44 PM
  4. El Guapo, ISCG or ISCG 05?
    By Cruizer in forum Titus
    Last Post: 04-24-2012, 01:33 PM
  5. Does this guide look like ISCG or ISCG 05 ?
    By keen in forum Downhill - Freeride
    Last Post: 02-27-2011, 05:27 PM
