Results 1 to 7 of 7
Thread: SB66 with X-12
    Dec 2011
    SB66 with X-12
    Hi
    I am a bit ticked off about finding information about the Chip system and drop outs on our SB66 frames.
    I am considering changing wheels to either Syntace or Fulcrum and still keep a 12mm rear axle. How can I convert my chip to x-12?
    Reputation: adamkob32's Avatar
    Oct 2012
    Oni
    Oni is offline
    Master Of Fooliganism
    Reputation: Oni's Avatar
    could be wrong...
    Quote Originally Posted by mahrous View Post
    Hi
    But I think the Syntace system is NOT compatible with the Shimano set up.
    Syntace
    Oni
    Chilling out
    Reputation: bear's Avatar
    Mahrous, what is the hating about the chip system?
    I do not think that the bike(s) can be converted unless you fabricate replacement chips that implement the syntace setup.
    I can not imagine a way it would be worth the effort.
    Sent from my Nexus 7 using Tapatalk HD
    Dec 2011
    Hi guys
    I am sporting the stock X1600 wheels from the Enduro Plus build with a 142x12mm drop outs installed.
    I was close to buying the Fulcrum Red Metal wheels and I am not interested in going 'back' to QR system and lose a bit of rigidity.
    The Fulcrum are available in X-12 and QR.
    What does that mean? Can I use the Fulcrum with my stock 12mm thru axle? Or do I need to change anything?
    Chilling out
    You can use those wheels on the non-Syntace setup, they're still 142mm wide with 12mm axle.
    It's the axle that must match the frame dropouts, the hubs are cross compatible.
    Reputation: Dogboy's Avatar
    Quote Originally Posted by bear View Post
    Quoted for truth. Any 142x12 rear hub (which any hub designated X-12) is compatible.
  1. Uzzi or SB66
    By TBarnaby in forum All Mountain
    Last Post: 09-13-2012, 03:15 PM
  2. 575 vs SB66
    By nhodge in forum Yeti
    Last Post: 06-28-2012, 08:15 AM
  3. SB66 spares UK
    By RocketMagnet in forum Yeti
    Last Post: 05-23-2012, 11:39 AM
  4. SB66 and other air shocks?
    By jgusta in forum Yeti
    Last Post: 12-16-2011, 07:59 AM
  5. Build Kit SB66
    By PIC1 in forum Yeti
    Last Post: 11-17-2011, 03:16 AM
