Results 1 to 7 of 7
    Stray Bullet
    Reputation: Nagaredama's Avatar
    SB66 Stuck Pivot Axles
    Anyone else have the problem of their pivot axles getting stuck? Took my SB66a in to my local Yeti dealer to get the bearings replaces and the wrench broke 3 6mm hex tools trying to remove the pivot axles. Considering I live in SoCal and have ridden in rain once, I'm pretty disappointed they need to be cut out and replaced. The shop called Yeti and they said it wasn't a warranty issue. The pivot axles are $120, pretty weak.
    Anyone else had the same problem? Any tips for getting the pivot axles out with having to cut and replace them?
    Reputation: wilbcol7's Avatar
    Oct 2011
    Have not had the same problem. But I pull the pivot shafts regularly on my 95c and grease them.
    You did loosen the pinch bolts first, right?
    Stray Bullet
    Quote Originally Posted by pcemkr View Post
    Yes I loosened the pinch bolts first.
    Guess that wasn't it then.
    Stray Bullet
    Trust me I checked about 5 times, making sure I wasn't pulling a bone headed move and missing that.
    Chilling out
    Reputation: bear's Avatar
    Soak wd40 into the bolts?
    Sent from my Nexus 7 using Tapatalk 4
  1. Replies: 3
    Last Post: 07-21-2014, 06:59 PM
  2. SB66 pivot bearing problems
    By shizzlebizzle in forum Yeti
    Last Post: 02-14-2013, 07:19 AM
  3. SB66 switch pivot bearing issues?
    By jgusta in forum Yeti
    Last Post: 11-15-2011, 08:19 PM
  4. Rune pivot axles wearing out
    By cave dweller in forum Banshee Bikes
    Last Post: 11-15-2011, 03:56 AM
  5. Stuck / Frozen Pivot Axle
    By mtbiker278 in forum Santa Cruz
    Last Post: 06-23-2011, 08:57 AM
