Results 1 to 6 of 6
    Jun 2012
    SB66 - mounting hardware for Vivid Air
    Hi
    Im about to swap out the rp23 for a Vivid Air shock. What kind of mounting hardware do I need for the Vivid, does everything I need come with the new shock?
    Thanx.
    Jun 2012
    See also the Vivid Air has three different tunings. What will be best for the sb66?
    Mr. Knowitall
    Reputation: hssp's Avatar
    You have a LOT to look forward to. This is a really badass shock for the SB. I loved my Vivid Air when I had the SB-66
    I went for low tune and 21.8mm mounting hardware which fit like a glove.
    The shock comes with a pump, and I urge you to look at the vivid air setup video from the service pages at SRAM | Incremental enhancements. Perpetual improvements. Revolutionary Innovation., as it tells you how to pump the solo air properly.
    So what you need is:
    Shock
    Mounting hardware
    Then; SHRED!
    Jun 2012
    Thanx for feedback. The mounting hardware is this? Rock Shox Rear Shock Mount Hardware 1/2"x 1/2" | Buy Online | ChainReactionCycles.com
    Do I need any special tools for mounting this?
    What is the difference between the tunings of the shock? Can only find correct size with med. tune at the moment.
    Thanx.
    Jun 2012
    Found that the Vivid Air comes with this tunings;
    2.0-2.4 : 1 Leverage Ratio (Low Tune)
    2.3-2.8 : 1 Leverage Ratio (Mid Tune)
    2.7-3.1 : 1 Leverage Ratio (High Tune)
    Found the leverage ratio for sb66 to be 2,4. So both the low and mid tune should be good. Please correct me if Im wrong..!
    Mr. Knowitall
    Re: SB66 - mounting hardware for Vivid Air
    It depends, as it is also depending on the curve of the suspension design.
    Are you Norwegian?
  1. Vivid Air on SB66
    By kelvinkok in forum Yeti
    Last Post: 06-25-2012, 04:27 AM
  2. fox dhx rc4 mounting hardware
    By dave_128 in forum All Mountain
    Last Post: 03-12-2012, 05:13 PM
  3. fox dhx rc4 mounting hardware
    By dave_128 in forum Titus
    Last Post: 03-11-2012, 07:56 AM
  4. Do I need new mounting hardware?
    By dlorga in forum Shocks and Suspension
    Last Post: 02-07-2012, 01:02 PM
  5. Shock Mounting Hardware
    By gticlay in forum Santa Cruz
    Last Post: 02-08-2011, 08:38 PM
