Results 1 to 5 of 5
Thread: Sb66 cable rub
    Sb66 cable rub
    Simple question how do you stop cable rub to the rear break?
    Chilling out
    Reputation: bear's Avatar
    You don't say WHERE it's rubbing that you are concerned about, but I imply the yoke down near the Switch.
    On my '95 I zip-tied the rear brake housing to the vertical on the rear triangle, so it would stop rubbing on the yoke. Ugly, but functional. I wish Yeti had made provision for an internal routing on that side, like they did with the derailleur on the other.
    Sb66 cable rub
    Yeah indeed bear I didn't but your quite correct. That's the section. It worries me cause I can't see how to stop it. Can't even get copter tape to stay there.
    Will give your idea a go thanks for the reply!
    I wish they had done this too!
    Jun 2010
    I used the soft side of sticky Velcro, heat it up with a hair dryer and it will stick like a charm
    Sb66 cable rub
    Money cash that's a nice touch!
  1. Naked Shifter Cable or Full length Cable Housing?
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 04:02 AM
  2. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  3. 6mm Gear cable ferrules and suitable cable?
    By Rick Draper in forum Vintage, Retro, Classic
    Last Post: 09-23-2012, 02:01 AM
  4. 575 vs SB66
    By nhodge in forum Yeti
    Last Post: 06-28-2012, 08:15 AM
  5. QBP cable housing $1/ft; Sram Derailleur cable $2/set; free ship over $30
    By bob13bob in forum Where are the Best Deals?
    Last Post: 03-29-2012, 06:51 AM
