Page 12 of 15 FirstFirst ... 2 8 9 10 11 12 13 14 15 LastLast
Results 276 to 300 of 369
  1. #276
    Dec 2011
    I demo an XL and ride an XL 575 and it was a good fit
  2. #277
    Snapper
    Reputation: johnd663's Avatar
    thanks for the big bloke thoughts - I have pulled the trigger - so excited - now 1 x 10 or 2 x 10?
  3. #278
    Reputation: Just J's Avatar
    Feb 2005
    I'm 227lbs and I've decided that I'm going 2x10 XTR Trail as it gives the perfect spread of gears. At least until I get SRAM XX1.
  4. #279
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    Quote Originally Posted by johnd663 View Post
    thanks for the big bloke thoughts - i have pulled the trigger - so excited - now 1 x 10 or 2 x 10?
    1x12
  5. #280
    Jan 2013
    The carbon upgrade -
    This bike isn't the same going from a to c. It's unreal
    SB 95 Build Thread?-419597_10200682107991565_174299424_n.jpgSB 95 Build Thread?-968896_10200682108031566_526385115_n.jpg
  6. #281
    Lucky...
    Is the seat at the same height (to pedals) in both the above shots? Looks like less post exposed on the carbon frame, which would mean I need a different dropper to make the switch.
    Yeti SB-95a Black
  7. #282
    Chilling out
    Reputation: bear's Avatar
    y'all are dropping 2# by spending $$$ on your ride, I'm looking at doubling the weight of my shock by spending $.
    I dunno who is crazier.
  8. #283
    Dab-O-Matic
    Quote Originally Posted by bear View Post
    We're all a little bit crazy.
    At least for me, going to a CF frame is about feel, nothing else. And no, who can financially justify this stuff?
  9. #284
    Jan 2013
    Same seat post - it was just further down when the pic was made. I only got the carbon frame - I put everything from my alloy on the carbon - same geometry.
    So after I sell the alloy w/ a CK headset I'll net -$1200-1300. But it's not the weight (although climbing on the carbon is like nothing I could have imagined. I don't even feel like I'm working my legs, so yeah that 2 lbs is complete ride changer). I race 30-40 mile races in GA so that alone is worth the cash. But the stiffness is insane. I've never rode carbon, but I can say the wash-out feelings of the 29er are gone. It rails through corners, and flicks like I remember the 66 feeling.
    But can I justify the cash out? Only to myself, no one else would get it
  10. #285
    Chilling out
    Oh, I "get it" too ... just no way I can get it.
    I'm "banking on" the carbon upgrade for when I break the alloy.
    It's only a matter of time.
  11. #286
    Dab-O-Matic
    BTW Bear...you have to change your moniker to "Destroyer of shocks".
  12. #287
    Chilling out
    Quote Originally Posted by Simplemind View Post
    Oh gawd, I hope not.
    Although, I have spent enough on tires to buy a CCDBAir at this point.
    Sent from my Nexus 7 using Tapatalk HD
  13. #288
    Lucky...
    Money spent on tires is a seriously depressing thought. Given my fondness for Schwalbes, I am thinking I have spent about 1k on tires since buying the bike.
    Yeti SB-95a Black
  14. #289
    Dab-O-Matic
    Quote Originally Posted by Mr Bacon Jr View Post
    Are both of you running 140 Floats? I'm thinking of remodeling, and trying to find a better fork. I'm afraid the 140 might be a bit lanky, but maybe not. The new Formula Thirty-Five or the Pike looks like good candidates, but the Pike is at 140, the Thirty-Five is adjustable.
    Nirvana for me would be an 1800gm 130mm coil.
  15. #290
    Chilling out
    simplemind, I've been a coil+oil guy for a LOONG time.
    but.
    I really REALLY like how my 29 Float 34 works. It's great.
    That said, my '13 model is currently at 140mm travel. It was 120mm as I received it, it had a 20mm travel limiting spacer in the bottom of the air chamber. Truly easy to pop out.
    I am planning on putting in a 10mm spacer the next time I'm in the fork, to try it out at 130mm travel.
    I've run it at both 120 and 140, and wasn't unhappy either way, so I think at 130 I'll end up with that happy medium of "maximun DH-ish-ness" vs "most agile".
  16. #291
    Lucky...
    I've run my '12 model 29 Float 34 at 120mm for it's entire life (about 2,700 miles) and have really liked it. Have been setting the bike up a bit plusher lately, and it still rails. Have thought about doing the 140 mm setting for a while, but left it as is when I rebuilt the fork at 2k miles.
    Yeti SB-95a Black
  17. #292
    oot & aboot in Colorado
    Aug 2010
    Can you describe the procedure or is there an online guide or something for doing this conversion? I spent a couple of hours playing in a rock garden on my sb95 on Sunday and a little more would have been fun to play with...
    tia,
  18. #293
    Chilling out
    Quote Originally Posted by Geek View Post
    - drain air from air spring
    - drop lowers off (you should be able to find oil service info on the ridefox.com or related site)
    - rotate fork so legs are horizontal, or pointing slightly up (otherwise you'll need float fluid to replace in air spring)
    - using c-clip pliers to take clip off bottom of air spring
    - GENTLY pull the bits out the bottom of the air spring until the travel spacer is visible
    - snap the travel limiter off
    - reassemble
    you'll want to get oil for the lowers, takes 30ml per side if I recall correctly, 10wt
    again, there's service info on the fork on the fox site, also lists tools needed.
    disclaimer: I've heard that the late model forks may have changed, so I can't say for SURE your fork has the spacer, but it is easy to find out. My fork is a '12 34 Float 29.
    have fun, good luck!
  19. #294
    Lucky...
    CTD model forks have significantly different internals, I am told. Check for the Fox service videos on YouTube- very helpful.
    Yeti SB-95a Black
  20. #295
    I have seen first hand a Pike 160 on a 29'r. Just an FYI.
  21. #296
    Chilling out
    Mine is CTD.
  22. #297
    Lucky...
    Mine is CTD.
    Ahhhhh- yours was delivered during the switchover. I ended up with pre-CTD model.
    Yeti SB-95a Black
  23. #298
    Chilling out
    I got lucky on the fork, unlucky on the shock, life is a balance.
    OTOH, I've always felt that my rear shock was "this" much "behind" the DH capability of the fork (in D mode), maybe I'll finally have Complete Bike Balance with the new damper that I'll be getting. My RP23 felt nicely balanced against my fork, with the fork in T-0, but with the fork D it was out paced, now and then obviously.
  24. #299
    Dab-O-Matic
    Quote Originally Posted by Salespunk View Post
    Did it look like this?
    Of course, that's my concern. The SB handles so well at 120mm, I'm really leery of going too slack plus the added BB height, but it wb interesting to ride a 160mm.
    I'm in the Bear's camp regarding 130mm being an ideal compromise, until someone convinces me otherwise.
    I did notice the Ripley (yes, considering that one as well) is stocked with a 140mm, has pretty similar specs, and an even lower BB ht @ 13.25.
  25. #300
    Reputation: ridetheridge's Avatar
    Just picked up my Turquoise SB95 w/ Race Kit. Man it is a nice bike ! The color in pictures doesn't do it justice when you see it in person. Next to my 575, the wheels are huge ! Yes.. it is a 29er. I see why they call them "wagon wheels". I installed a 60mm stem and will have to order some black pedals. My gray pedals off my 575, just don't cut it. I'm sure the next rides will be tweaking the suspension etc. Hope to ride it tomorrow.
    BTW...Everyone in this Yeti forum are very helpful and knowledgable. Reading through this thread along with replies to some of my own postings, help formulate my decision in getting this bike.
