Results 1 to 6 of 6
    Reputation: wreckingrob's Avatar
    Sb-66 Switch Maintenance - Main Pivot Axle Removal...
    Went to do some regularly scheduled maintenance of my 66 and was stymied by the main axle pivot. The one going through the Switch Link. I tried inserting the bolt some and using a dead blow hammer to work it out, but get really nervous at the amount of force I was having to use. I stopped and focused on the dog bone pivots instead, which were dry. So, I know I need to get into the Switch Link and apply some greasy goodness.
    How are other 66 owners getting this axle out? I'm probably answering my own question here, but what about a wooden dowel of appropriate diameter to help push the axle out? What are you guys using?
    Yes, I did remove the pinch bolt...
    If your not wreckin', your not ridin'.
    ...on both sides!
    Chilling out
    Reputation: bear's Avatar
    if it's like the '95 bolts they're both threaded, so you first need to remove the locking one and then unscrew the actual axle.
    on the '95 it takes a 5mm to remove the locking bolt, and an 8 or 10 (I forget which) to unscrew the axle.
    when I take mine out I use the allen to help pull the axle out.
    i have no experience on the '66 so I don't know how it works, so YMMV.
    Reputation: mtnbiketodd's Avatar
    Check the Owner's Manual on the Yeti website it shows a 10mm for the axle for the 2013 66c
    FYI, this is a 66A, alloy... should have mentioned that up front... thanks tho.
    Jul 2013
    Did anyone figure this out? I'm in the same position, noticed the swing arm was flexing instead of the main pivot axle smoothly rotating out. The 5mm collet bolt has been removed since I am using a 10 mm allen to rotate it. I tapped the other side with a deadblow and its still stuck there pretty good.
    Edit: Got it with a dowel as suggested earlier. Gave it a good whack right on the bolt and it slid out.
  1. Replies: 5
    Last Post: 03-15-2015, 03:06 AM
  2. 575 main pivot bearing removal?
    By VaughnA in forum Yeti
    Last Post: 01-21-2013, 11:39 AM
  3. Source For Main Pivot Axle Hex Head Cover?
    By Eastcoaster in forum Commencal
    Last Post: 08-22-2012, 12:40 PM
  4. 575 Main Pivot Removal
    By GS_Ken in forum Yeti
    Last Post: 08-02-2012, 11:05 AM
  5. Replies: 4
    Last Post: 07-01-2011, 09:17 PM
