Results 1 to 5 of 5
Thread: SB-66+CCDBAir
    SB-66+CCDBAir
    Who is running one and what's your settings? Getting the XV Air Can installed now, and curious what's others experiences.
    Reputation: nybike1971's Avatar
    SB-66+CCDBAir
    Quote Originally Posted by pcemkr View Post
    The XV air can sounds like a bad idea on the linear SB-66 linkage. Hopefully you can throw enough volume shims in there to achieve a proper spring curve for the frame.
    I have a CCDB Air on a Knolly Chilcotin, which has a very progressive linkage, and I would not want to run an XV canister even on that frame. The new High Flow regular air can matches air spring and damping perfectly for my weight (165 lbs) with 30% sag.
    Reputation: Jeremy R's Avatar
    Yep, the high flow regular air can works perfect on the 66. As far as settings, Here are my baseline setting for mine:
    9 clicks of LSC
    .5 to 1 full turn of HSC
    10 clicks of LSR
    2 full turns of HSR
    Today, I raced a super d race that was fast hardpacked berms with g-outs, and today I ran 12 clicks LSC and another half turn of HSC.
    SEI Racing
    SB-66+CCDBAir
    Quote Originally Posted by Jeremy R View Post
    9 clicks of LSC
    10 clicks of LSR
    2 full turns of HSR
    Settings look good.
    Sore D at Fontana?
    Settings look good.
    Sore D at Fontana?
    No, it was the Warrior Creek Super D in NC.
    SEI Racing
  1. SB95 & CCDBAir
    By crux in forum Yeti
    Last Post: 05-14-2015, 09:07 AM
  2. TRc with CCDBAIR
    By XMAX in forum Santa Cruz
    Last Post: 11-23-2012, 04:27 AM
  3. Replies: 1
    Last Post: 08-12-2012, 07:04 PM
  4. Carbon sb66, yeti dj, CCDBair.. Pick two
    By swan3609 in forum Yeti
    Last Post: 03-27-2012, 01:34 PM
