Results 1 to 3 of 3
    Reputation: bridgestone14's Avatar
    Mar 2005
    SB-66 Bearing Replacement
    Ok, I am a pretty good mechanic and i have rebuild lots of frames, but I can't seem to figure out how to get the pins our of the suspension pivots. Is there a manual or a video somewhere that you guys can point me to? Utube, is failing me.
    Any help would be greatly appreciated.
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
    Reputation: mtnbiketodd's Avatar
    Did you check the Yeti website for the owner's manual?
    On my SB-66c the pins have a 10mm allen on the side that has the 5mm bolt as well.
    take out the 5mm bolt then put the 10mm inside.
    Mar 2005
    M1neral got back to me with the link to the manual on the website. Thanks, I am not sure how long it would have taken me to figure out I needed a 10 mm allen.
    http://www.yeticycles.com/pdf/manual...nual_SB66C.pdf
  1. 6.6 bearing replacement?
    By mazafakka in forum Intense
    Last Post: 07-17-2017, 08:47 AM
  2. Trance Bearing replacement How To.
    By LyNx in forum Giant
    Last Post: 07-16-2015, 06:58 PM
  3. Pivot Bearing Replacement RIP 9
    By attaboy in forum Niner Bikes
    Last Post: 11-28-2012, 02:03 PM
  4. Bearing Replacement
    By lax30 in forum Intense
    Last Post: 02-04-2012, 06:45 PM
  5. Stumpjumper FSR Bearing Replacement
    By StumpjumperUK in forum Bike and Frame discussion
    Last Post: 01-19-2011, 07:22 AM
