Results 1 to 33 of 33
Thread: SB-66 or ASR7
    Reputation: Nate3510's Avatar
    SB-66 or ASR7
    Should I take advantage of all of the smoking deals there are right now on the ASR7 or save up a little more and get the SB-66? I have heard nothing but good things about both bikes. Is it true that the ASR7 is being cut from the lineup? Any input would be greatly appreciated. Thanks
    Reputation: bpnic's Avatar
    Aug 2005
    Nate:
    tell us how you ride and we'll pick you a bike.
    I've owned both and am happy to help.
    Quote Originally Posted by bpnic View Post
    Nate:
    This is going to be my one bike. I do everything from x-country to downieville. So i am looking for a do it all bike if there is such a thing. Thanks
    Ka-coo-ka-cha!
    Reputation: snigs's Avatar
    Feb 2010
    Have you tried to search for this?
    Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
    Aug 2005
    Quote Originally Posted by Nate3510 View Post
    Ok, i'll do my best.
    i'm 3000 miles from d'ville, and not that up on it, but I get your point....
    the 7 is a great bike at a great price. it is a plush "typical yeti type" ride that descends and even climbs well.....for a seven inch bike. the shock rate for the rear uses all that travel everywhere, meaning you'll spend the entire ride deep in the travel.
    while this is comfy, it's neither fast nor efficient.
    the sb-66 is fast, firm and feels like less travel than 6". think trek remedy, but maybe even firmer with the stock rp23.
    it's not a hucking style all-mountain bike at all, yeti deep down knows this.
    it is though, a great all around trail bike.
    I preferred the ride of my asr-7 in most terrain, but the sb-66 has sped my riding up so much that i'm back up front on group rides. it is so much faster than the seven, that i'll live with the firm ride. I am not as comfortable sending it on the sb, but maybe it's me...
    my .02
    I'd hit it, but I bruise like a peach.
    Aug 2005
    Quote Originally Posted by snigs View Post
    I considered asking him, but figured, no.
    sniggs is right Nate, plenty of existing info covering and comparing the two!
    Dec 2011
    If nothing else, ask yourself how your boys will do with the 7's standover height...
    the 7 is a great bike at a great price. it is a plush "typical yeti type" ride that descends and even climbs well.....for a seven inch bike. the shock rate for the rear uses all that travel everywhere. you spend the entire ride deep in the travel. while this is comfy, it's neither fast nor efficient.
    my .02
    Thank you very much for the info!! Do you run a 150 or 160 fork on the sb66?
    Aug 2005
    Quote Originally Posted by spaightlabs View Post
    If you owned one, you'd know it's a non issue.
    (Originally Posted by zebrahum)
    You don't size a bike to stand over it. When you're riding the bike the saddle goes to the same height from the BB no matter what bike you're riding so if you can stand over the 7 then it's a great bike. Yes it's tall in standover, but that doesn't change how tall you feel on the bike. That has more to do with BB height and ETT, I would say.
    Z makes a great point.
    I had a 7 and I loved it. I also have a short inseam of 30" and stand about 5'10" tall.
    My medium seven never, ever felt "tall" or "weird". Ever.
    With it's leverage ratio, the bike squats nicely in it's 7" of travel, so there's never really a tall feeling.
    But as Z mentioned, the saddle to pedal distance is set (usually) the same distance from this bike to your last bike... no matter where the top tube is.
    __________________
    Aug 2005
    both.
    a lyrik uturn 110-160mm coil and a fox talas 120-150mm. 45mm stem.
    With the sb's geo, i prefer the 150 for everything but shuttling, mainly because of the much shorter axle to crown height.
    Reputation: KrisRayner's Avatar
    Have you ridden the 7 with a coil shock? I found what your saying to be true with the DHX air it came with. But due to how much air I had to run because of my weight, I switched to an RC4 coil shock and love it. No more wallow, just nice smooth travel when I need it. Plus with the low and high speed compression adjusters, I've been able to tune out most all pedal bob. Still not as effecient as an XC bike, but makes up for it in spades over the rough and decending.
    BTW, I was able to sell my DHX air and upgrade to the RC4 for a total of probably $100.
    I have yet to have ridden an SB66. I came from a '08 575 (PUSH'd) to the 7 because of the great pricing at the time and don't regret it. I wanted to be able to run a coil shock and have a bike better suited for doing lift service runs.
    I'm sure the 66 has a better suspension setup, but you have to ask yourself if you think it's worth the price premium right now. I say pick up a 7 and ride the crap out of it and love it. By the time you grow tired of it, the 66 will have come down in price and be a much better deal. Both frames use the same size shock, so that could be transfered over as well if you upgrade the 7's shock and both can use the same 160mm fork, so it's not like you have to replace the whole bike if you decide to go with the 66 later.
    Reputation: GreenBonty's Avatar
    both.
    Hey bpnic
    Do you drop your TALAS to 120mm at all?. Do you find it usefull in rocky rooty terrains?. No pedal strikes at 120mm?.
    I have the TALAS (since there were no floats last week) but did not imagine I'll ever use it.
    The bike is so natural at 150mm no matter where you take it............
    By the way, for the sake of this thread I have never rode a 7 for more than a parking lot 1 min ride but knowing the different 575 models, I find it hard to believe that the 7 can climb nearly as good as the SB. The shock may make a difference but it will never close the gap in climbing efficieny and tracking the SB has.
    As for speed, yeh, totaly agree that SB has a remarkable speed not just over the 7 or 575 but even over Mojos that are way lighter and sport the DW for peddaling. The SB is realy a super peddaler all around.
    On the way down the chunk, I believe the 7 wins hands down.
    jddist
    Quote Originally Posted by KrisRayner View Post
    +1. At the current price of the 7 this would be my route. I have a 7 and a Firebird and like the 7 the most, and that is with the DHX air. I still have yet to move to coil.
    Aug 2005
    Quote Originally Posted by GreenBonty View Post
    Hey bpnic
    GB,
    I rarely use the Talas at 120mm, the few times i had, the trail was pretty steep and the front end was starting to wonder. It's nice that is is an option though, just in case, but the bike is set to full travel most all the time.
    as for the seven climbing....it climbs well for a seven inch bike, mostly due to the active suspension. the sb isn't nearly as active, so it loses points there, but scoots up climbs none the less.
    i owned a mojo, and the ride was a touch softer. the sb feels firmer and faster.
    Aug 2005
    Kris-
    i'll take your word for it, i did not try a coil, but probably should have. The seven was my XC bike as well, so I stuck with the air can.
    I agree with you on the second point too, snatch the sevens up while you can-
    Reputation: jgusta's Avatar
    the sb-66 is fast, firm and feels like less travel than 6". think trek remedy, but maybe even firmer with the stock rp23. it's not a hucking style all-mountain bike at all, yeti deep down knows this. it is though, a great all around trail bike.
    I don't know, I think the 66a with right parts can handle most things AM quite well (even though that is kind of an ambiguous term) with burmy, jumpy, booty, dropping, fast and rough stuff and yet feel nice and snappy and very "trail-like" when ridden on your standard trail rides as well like you mentioned.
    I have been hammering mine with 32lb build on everything (4-5x/wk) here in PacNW for almost a couple of months now, including runs/trails that typically only people shuttle with high speed, wide singletrack runs littered with good sized booters and tables and the SB66 feels solid to me bombing, launching, and landing even with stock air configuration at 30% sag and +200lb rider. My last bike was tagged as an AM/FR bike and the 66, at least how I have it built for me (Lyrik DH, Saint brakes, SLX cranks, Mallet pedals, wide bars/short stem), feels even more versatile. I can comfortably do +3500' trail climbs followed with smoking descents. Feels like a great DH trail bike to me that jumps well too with great standover to get a little styley in the air as needed with great ramp up for the hits and nice plush, stable landing with no harshness or bottom out at all. I am always impressed how well it handles square-edged hit in my neck of the woods, like tree stump booters and roots. The 6" feels somewhat "bottomless" to me with EVO floater- like suspension (Remedy, Slash) as compared to my previous bike which was 6" and more VP-like in performance with chain forces and suspension dependent upon the other.
    So far this bike has been a very soild, versatile machine for me and I would argue that it does handle AM stuff quite well with a solid 160 fork and the right parts.
    Ride On!
    Aug 2005
    Quote Originally Posted by jgusta View Post
    J-
    You certainly make a valid case for an climbing and hucking type Sb.
    We can almost dress up any 5 or 6" bike with a coil rear and a 36 up front, meaty tires, dropper post, tiny stem and a set of Boobars and make it funner. But If I was lucky enough to ride Whistler or Highland (NH) regularly, I think I'd opt for something like an Uzzi, Reign X, Canfield, or an Entourage. Maybe even a FB or HD.
    Lately, it seems the kids fill my Summer weekends more than the chairlift, so my Sb unfortunately isn't tested like it should be.
    J-
    I never ridden the SB66 at a bike park, so couldn't really tell how it be in that kind of terrain/situation but imagine it to handle like any solid AM would w/160 fork and air suspension to compare fairly.
    At my local bomber trails where you have to climb fairly long steep grades to get to the goods to rip down, I couldn't imagine a better bike for me, but I guess I am a little biased and still under the "new bike buzz". So far I would take this over a Nomad, Rune, FB, and possibly even a HD (but that is kind of a toss up for me) especiallly a HD w/coil at about the same weight as SBa w/air and possibly more capable?
    In the end, the SB really is a really FUN bike for me to ride on the kind of terrain I spend most my time on in NW Oregon/SW WA with mostly buffed, loamy, rooty, some loose, some rocky, burmy/carvy/jumpy rippy terrain with just the stock RP23 air (never particulary liked RP23 when ran on bikes before), All this makes the SB feel like a total, do-all trail/AM assasin to me!
    Ride On!
    Member of The Yeti Tribe
    Reputation: swan3609's Avatar
    Space reserved for huge ASR-7 post and video shoing how rad me and my ASR-7 are when I get out of class.. And I do everything from 24hr races to downieville to race downhill on my 7..
    Sent from my Transformer TF101 using Tapatalk
    Stop this Derailleur Madness!!.... De-Rail-er
    See what the God of bikes has to say about it..
    Reputation: socalMX's Avatar
    Im also a bit curious to maybe pick up a 7! Strange thing is the sizing on the 7! I currently have a Large 2010 Nomad, im 6-1 with a 32" inseam. The sizing listed on Yetis website puts the dimensions of the Medium 7 ALMOST exactly to my Large Nomad. In fact, the TT on my L Nomad is 22.5 (center HT to center ST) and the M 7 is listed LONGER at 23.6"... The ST length is the same as is the axle to axle... Strange! Should I go with the Medium 7, or go L??? Anyone have seat time on both to compare? I have had Nomads for 3 years and love em, but would like to try something new!
    6'2" here with a 34" inseam and I came off of an '08 575, size Lg, to a '10 ASR7 size XL. Top tube just a little longer than the lg 575, but with a shorter stem (70mm) it's just right.
    From everyone's review I thought I might need a Lg 7 but from experience I found the XL to be right for me. I think the seat tube able of the 7 makes the top tube length a little longer.
    Dam thats a big bike! I like how my Nomad feels and a bit afraid of having a bike thats too big! I like the bike more maneuverable. My thought is if it specs out the same dimensions I should be comfy, UNLESS Yeti makes the bike bigger for a reason?
    Quote Originally Posted by swan3609 View Post
    Tic Toc
    Quote Originally Posted by socalMX View Post
    Are you measuring effective top tube? On competitive cyclist, they show a 2011 Nomad effective TT to be 23.8" on a Large and 22.8" on a medium. Medium ASR 7 it shows as 23.6" and Large as 24.6". My '08 575 Large had a TT of 24.9" and my XL ASR7 is 25.6", but I went from a 110mm stem(575) to a 70mm stem(7).
    How is the cockpit setup on you Nomad?
    Effective TT??? Yetis site has the TT dimension measured from center of HT to center of ST, so I walked outside and measured my L center HT to center ST to be 22.5 and the 7 med is 23.6 listed. To me that would give me a bit mor room going from my L down to a M???
    Effective top tube is a horizontal measurement from the center of the stem to and imaginary line of where the seat post would be at that height. A more "real world" measurement, since so many manufacturers measure it differently.
    Gotcha, I broke out my level and it did grow about 1/2" to 23"... Still shy of the 7s 23.6 for the medium. Im comfortable with the size of the Mad, hoping I will be o.k??? Wheelbase on 7 is 45.5, my L Nomad is 45.2...
    To the OP, sorry man did not mean to hijack your thread! If I were you I would go with the 7.With the extra $$ you could buy better components!!!
    what the quan?!
    Reputation: dangdang's Avatar
    Can't wait to see it man. I should have some vids in the up coming weeks or so too... got my work to approve the purchase of a gopro for "work" related functions!
    Reputation: krazychowmein's Avatar
    I've got a buddy who swears by his ASR7, when Competitvecyclists started blowing out the 2011 frames I couldn't pass up the deal. Received the last bits of my build this week, pics in the ASR7 build thread to come!
    Sorry no opinion on the SB but wanted to let you know I was in the same boat
    Boom!! post about the ASR7 as I promised.. sorry it took so long, It was a busy week getting back to school and I had a few Drs appointments to help fix my broken wrist that took alot of time and effort,,
    I will discuss my opinion on the 7.. I am sure if you guys have been around much you know I love my 7..
    I do believe that I am probably about the best example of the rider for the 7, and unfortunately there there is a very few of us that ride like I do.. I raced for mongoose at the grassroots level and at the time had a dedicated DH bike, AM bike and an XC bike.. most of my time was spent on a 35lbs AM bike that was built more as a light freeride/All mountain bike. I had a set up with multiple bikes that did their respective jobs very well. I then had life hit and had car payments and other life responsibilities along with my Dh bike getting stolen led me to the point where I needed one mtn bike to cover all my needs..
    Unlike most people, my needs spanned a few very different genres of riding. I do race cross country against guys on 21lbs bikes and do tend to hold my own. On the other end I race Dh at the Semi-pro level and needed a bike for some of the smaller local courses, I was not expecting a bike to tackle world cup full rock gardens and such, but I did need a bike that I could beat on and would take it. Most importantly most of the time the bike would be doing what most of us do every time we ride. I would go out to my local mountain, pedal up to the top 3000ft later and ride back down a trail that was built for the average trail bike. I would say that my specialty is Super D races and every year I podium at Downieville in the Expert all-mountain class, so I needed a bike I could climb on but still come down hill on..
    I looked all around and was about to pull the trigger on a used Sworks Enduro, then I was going to go for a Stumpy Evo, then a 575, then I flipped to the 7 in our shops yeti book and I was confused by the bike. It had 7 inches of travel and almost XC like geo.. I dismissed it at first and then about a week later I realized that it could very easily be my next bike. I built it up with a lyric 2 step air, wide carbon DH bar and a 2x10 XT kit to about 32lbs and I could not be more happy with the bike. I can climb the bike with the 23lb guys around here, and have been on the podium of a local DH race with the same build kit on the bike as I race XC on. Its not perfect for either but it does well at both.
    I really do think that the 7 is a great bike, but I agree with the guys at yeti. I dont see the need for another bike like the 7.. I see the need for a burly AM/lightweight FR bike similar to the ASX even if there is not a huge demand for it, It would be the bike to sit between the SB66 and the 303.. I feel as though the SB66 closed the gap between the 575 and the 7 and has made it so that the 7 is not needed in the lineup anymore..
    I love my bike to death, I just dont see many other riders riding hard enough while still needed a XC bike.. I dont think that the market for the 7 was ever that big.. I just happen to think that the 7 was the bike that was built for me.. I cant think of how a bike could be better suited to do all I need in a bike.. and this is especially considering the fact that most riders have multiple bikes now.. I am not going to lie that if I could have a 24lb 5 inch trail bike and a 303. I would do that in a heartbeat over my 7... Just I needed one do it all bike and the 7 fills that need..
    I honestly believe that a 66 would fill the "one bike" position for 99% of the riders out there better than the 7.. I believe that most wont be able to push the 66 past the breaking point, where I can justify the extra travel of the 7 because I do race full on DH on the bike and I am not sure if the 66 will handle the abuse I put the 7 though, plus I know the 7 can handle a 180mm fork if I ever get enough money to buy one, as it was designed to ride with one.
    If the guys there are able to convince me about the Dh ability of the SB-66 then maybe my 7 frame will go on sale to try out a 66.. I just love the fact that my bike has hit 25 foot doubles, a few 15 foot drops and been on the podium of a DH race against DH rigs, and on the podium of XC/ Super D races all with the same 32lb build kit
    however there is the fact that the 7 can be had for much cheaper then the 66.. I understand that money can be a very important consiteration too and will probably be the biggest reason holding me back from moving to a 66..
    Quick edit down here in Boise
    <iframe width="560" height="315" src="http://www.youtube.com/embed/XqTv5TjxhVE" frameborder="0" allowfullscreen></iframe>
    Stupid video for school, but shows what the 7 with a 160mm fork, 2x10 drivetrain and "All Mountain" build kit can take..
    <iframe width="1280" height="720" src="http://www.youtube.com/embed/o_E_ixJK0JA" frameborder="0" allowfullscreen></iframe>
    Tell me if videos work.. I am posting from my tablet while my big computer renders out school work.. plus my tablet was within reach while the big computer is all the way across the room.. haha
    2 things first, I wish I had a place to ride like that, second I wish I had your skills! Sick vid! O.k, nice writeup! I have been on my Nomad for a few years and really love it but wouldnt mind trying something new, at the same time I cant spend a ton of $$ on something like a 66! I could pick up a new 7 frameset for a little less than what I could get for my Nomad frame, and almost all parts will swap over. Seems I would only need a front der. and a headset. My current rear hub has a 12mm thru axle! BUT I def. dont want to downgrade! Have you ridden a Nomad to compare? Also im still trying to figure out the sizing! I like the fit of my large Nomad and the numbers on the medium 7 are almost spot on! I like a tighter cockpit making the bike more flickable, im thinking the large might feel like a boat to me??? I know I will like the shorter chainstay! Another thing, I will be running a RC4 with a Ti-coil!
    I have not ridden a Nomad enough to really compare.. just rode a buddys Nomad carbon for about half a mile.. But if I was tight on cash then I would totally go to a 7..you will not be dissapointed..
    As far as sizing.. I would go with a Med I am pushing 6'3" and my large still feels long to me.. not unrideable long, just really long compared to my last few large bikes and it feels like a monster comping off my Dj bike.. I can still moto whip and flip my 7 so its not horrible, just its a big bike. That said, High speed stuff the bike is very stable and planted.
    I think the RC4 will be a great shock for the 7.. I blew up the RP23 on mine and I was never really happy with how the RP23 rode on that bike.. I hope for either a RC4 or a vivid air for my bike for next year if I cant manage to change frames..
    Cool, good thing is, the Nomad also uses a 8.5x2.5 shock so that will be an easy swap! Thanks for the sizing info! Thats what I figured! Only thing is the M has about a 4.5 inch tall HT and the L is over 5" ,not sure where the difference would be felt?
