Replacing the Fox Shock Bushing
excellent thanks, glad I got my LBS to do and didnt try and do with a hammer and bolt !
Cost here in NZ US$ 25.00
awesome pictorial, Flip!
one detail though...aren't bushing supposed to work completely dry? I thought grease actually increased wear and they were "self lubricating".....I am sure mtnbiker4life will drop by and clear this doubt...
ah...seems I misunderstood...
I just reread that part from the bushing tool instructions
"Rub a light coating of grease on the Ejector Pin o-ring then place a new bushing on the
Ejector Pin. Place the Support Foot into the counter bore on the Bushing Guide as shown.
Then slide the Bushing Guide onto the end of the Ejector Pin. At this point you will want to
position the slit in the new bushing so it opposes the direction of shock travel. Also, to make
the installation a little easier you can add some grease to the outside surface of the new
bushing. Now press the Ejector Pin until the front side of the bushing is flush with the other
side of shock/Bushing Guide. Carefully remove the Ejector Pin.
Before installing shock spacers rub a light coating of grease on the surfaces that will contact
the new bushing. Even though, these bushings are designed to be run dry and the bearing
surface material is extremely durable any excessive rubbing will degrade bushing longevity."
trail "cleaner"
Very cool Flip!
Thanks for posting. I'm gonna go get one of these . Oh.... BTW you need to get this... Then you can really use that vice
http://www.calcarcover.com/product.aspx?id=591&cid=31
No dabs allowed!
 Originally Posted by AZmtncycler
Dude... I was looking for those at Harbor Freight a couple of weeks ago. I'm thinking that I can just use some old inner tubes wrapped around the jaws for now...
The tool is surprisingly affordable (it will pay for itself the first time you use it).... And with the number of bikes that you have with Fox shocks and the way the bushings wear out on a 6 month basis, you'd be ahead in less than a year...
trail "cleaner"
Ha.. good one.
Well, you'll be happy to know that my stable has been reduced to only 4 bikes now Three using Fox shocks though.. So, I'm ordering 6 bushing along with the tool from Vince. Thanks again Flip for posting the good stuff!
trail "cleaner"
I like Monkeys
I had mine replaced about a month ago. My great LBS (Bikes Unlimited Lynchburg Va) replaced it at NO COST. My bike was about a year old. They said it shouldn't be like that so soon so they took care of me. Great shop!
What do I want to be when I grow up.....Dead!
Aye if you lift your bike up by the rear end unweighted (thats u off the bike) and it knocks or you can feel play replace you bushings. Also you can often see the tiny movement which confirms it's the shock busings worn and not something else.
I assume most people basic service their rear shocks - air can clean etc. As long as you've got the correct tool and the correct bushings this is a pretty simple job actually.
If you can take your shock off - clean the can and regrease then refit - thats the hardest part already done IMO - pushing out the old ones and pressing in the new ones with the tool is pretty idiot proof imo as the above pictorial demonstrates. Only without the right tool is it risky.
Personally the first time I had ever mine done on a bike I got them replaced at the service centre (for a major service) - once you get the tool and have a vice however the bushings replacement is a 5 minute job and nothing to be really scared of. Of course if your not sure then it's worth getting your LBS to do it - but it's really really simple tbh and if i can do it then I assume most people can.
A few years ago when I started biking I knew nothing about bike maintenance and I worked up from simple tasks to the more complicated stuff by reading the various books. I reasoned that when i'm biking in the middle of nowhere I need to know how it all works and how to fix it. Now i've got no reservations in building a bike from scratch and i'm suprised how easy it really is.
anybody know where i can get one of these bushing tools (online maybe) and bushings?
Forgot all about this tool. I'll order one now.
BTW - The Yeti linkage tool is on Jenson for $20.
I finally got around to replacing the bushing on the rp3 of my wife's 06 575, and I just wanted to say thanks to flipnidaho, jeremyp11, and mtnbiker4life.
mtnbiker4life's bushing tool, and this thread and bits of info from the following threads (with pics and steps) from flip and jeremy made the whole process VERY easy.
RP23 Woes...Today just was not my day!
Blown RP3 help...
Thanks,
Ant
Gotta love the tribe!!
where can i get the eyelet bushings
From your local bike shop - they are pretty common and cheap.
A green bird with a red body. We could look it up in a book. Or we could look up
or you could swtich them to needle bearings. 50+ bucks for a set
http://www.enduroforkseals.com/id276.html
trail "cleaner"
not for the 575
If you own a 575, you are stuck with the DU bushings.. there isn't enough space between the dog bone and the shock to fit these needle bearing kits
You really do not need the needle bearings on the lower shock mount, as the dogbone and seat stay both have cartridge bearings, keeping things smooth. You can however mount it on the upper mount. I did My opinion is that the bigger movement on a pivot, the more you will benefit from upgrading to needle bearings from bushings. My ASR has needle bearings on both eyes.
I have a knocking sound on my 09 575, but not from lifting the back, when I put weight on the saddle and push down there is an annoying knock which I can also hear when riding, my LBS have tightened all bolts and checked the shock bushings but can't seem to find any thing, I have taken seat post off and it's still there, I have swapped forks recently and still there, I've removed cables and swapped wheels. Please can any one help
trail "cleaner"
hard to say but...
try cycling the suspension with the shock disconnected at the upper mount. At least you can then feel for what may be binding up. Does it knock at the same location every time?
Disconnected the shock at the top mount, but it takes a bit of weight onto the top tube or saddle for it to knock.
trail "cleaner"
same position?
does the knock occur at the same spot of the suspension cycle? If so, it might be the bearings in the dogbone.
Yes it seems too, I will check the dog bone bearings, thanks
- You may not post replies
- You may not edit your posts
Forum Rules
