Results 1 to 7 of 7
Thread: Rate My Yeti
    Rate My Yeti
    By far the best bike I have built, and I have owned a lot of high end rigs. Tell me what you think?? Suggestions? Changes?
    * Frame Size & Color: 06 Yeti ASX, Large
    * Rear Shock: Fox DHX 5.0 Coil
    * Fork: Manitou Sherman Break Out Plus
    * Brakes:Hayes Mags 203mm rotors, Dangerboy Levers, Goodridge lines
    * Cranks: Diety w/ integrated BB and e13 Guide
    * Front Derailleur: N/A
    * Rear Derailleur: Sram X.9
    * Pedals: Diety
    * Stem: Answer one point five
    * Handlebar: Diety
    * Seatpost: Thompson
    * Saddle: THE Team FR Ti
    * Bottom Bracket: Diety integrated
    * Cassette: Shimano SRAM 990
    * Chain: SRAM PC909
    * Headset: Chris King
    * Grips: ODI lock-on
    * Front Tire: Maxxis Minion
    * Front Rim: Azonic Outlaw
    * Front Hub/Skewer: Azonic- 20mm axle
    * Rear Tire: Maxxis Minion
    * Rear Rim: Azonin Outlaw
    * Rear Hub/Skewer: Azonic, Hope Skewer
    * Shifters: Sram X.9 Trigger
    * Seatclamp: Thompson
    * Chainguide: e13 srs guide
    * Weight: 37.5lbs
    Reputation: goRz's Avatar
    May 2005
    I'd change this Manipoo and keep my fingers crossed for the DHX to be he non-clunking one.
    Passion beyond reason!
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by cmb2874
    I'm not qualified to suggest much on an AS-X, so I'll keep it simple.
    I'd look at one of the new RS forks (Lyric/Totem/etc) and get the DHX PUSH'd. Other than that, its a fine looking ride.
    DHX has a season on it and it is great.
    I have a Marz 66rc2x comming in. I'm a little nervous about running reducer cups.
    In my mind, I can do it!
    Reputation: iviguy's Avatar
    I would have to test ride it to give you a firm rating...
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Ditch the Azonic Outlaw QR and get a step down axle for the 12mm hub. The shallow drop outs and a crappy QR are a recipe for disaster. My rear wheel fell off resulting in a separated shoulder, not fun.
    The AtomLab step down axle is the best I've found. Don't waste your time or money on the Azonic step down axle. It chews up the drop out and doesn't secure the wheel as well.
    Atom Lab axle from Ride-This
    I'm running a 66RC2X with a FSA reducing headset. It is a huge step up in small bump performance compared to the Sherman with SPV.
