Results 1 to 5 of 5
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    ok..here goes....help needed with '12 575 build
    Yeti's site won't be updated till the end of the month.
    What Shimano front der. do I need?
    What Cane Creek headset do I need to make a standard 1 1/8th fork work with the tapered headtube?
    I think that's all I need to know right now.
    thks
    EDR
    Jun 2005
    Assuming the '11 and '12 are the same it looks like I need a direct mount E type. That being said, top swing, dual pull? Would that do the trick?
    Reputation: Troutinco's Avatar
    I wish I could help better here but I cant.
    I bought my 575 as a kit so it was done for me. I sent an email to get a frame manual for it and was told the 11 and 12 are pretty much the same... Being a newb to this nice high end bike and parts I'm still learning things.
    My front derailer: the cable comes up from the bottom and seems to pull down. Hope that means more for you and helps.
    2012 Yeti 575
    2013 Niner AIR 9
    2015 GG/DH
    Build in process 2017 Canfield Bro. Nimble 9
    EDR
    Jun 2005
    Sounds like a bottom pull, top swing. Thanks for posting.
    No problem. Pretty sure it does swing from top. Definitely bottom pull, the cable is routed up from the bottom of the BB.
    I can't help with the head set unfortunately beyond saying it is a cane creek 40 headset for a tapered steer tube.
    2012 Yeti 575
    2013 Niner AIR 9
    2015 GG/DH
