Results 1 to 3 of 3
    Reputation: KevinGT's Avatar
    Dec 2012
    How to clean pivot points
    I'm getting some squeaking from my new ASR-5. It's only about 3-4 months old but I've been riding it a ton and in horrible weather (including being completely submerged in a stream during a massive rain storm).
    The owners manual says to "clean pivot points" after a month. Exactly how do I do that? Do I remove the bolts and sleeves and take the pivots completely apart? Is this something I can do on my own or should the shop do it? I've got a torque wrench to reassemble it all properly.
    Chilling out
    Reputation: bear's Avatar
    I'd just unbolt everything, clean/wipe it out, grease as directed, reassemble.
    I dunno about the ASR-5 but the SB95 was a piece of cake.
    Just Ride!!!!!
    Reputation: mecam's Avatar
    I use an air compressor set at 40psi and blast every pivot points, always gets rid of the creaks. Also re-lube pivots every 500~1000 miles is a must.
  1. El Guapo V.2 Pivot points
    By mvt20ten in forum Titus
    Last Post: 08-11-2012, 08:38 AM
  2. FSR Pivot Points
    By stumpy6 in forum Specialized
    Last Post: 07-05-2012, 02:36 PM
  3. maestro pivot points squeaky/creaking
    By absoluteczech in forum Giant
    Last Post: 06-22-2012, 05:33 PM
  4. Lube protocol for rear triangle pivot points?
    By C83L5oD in forum Beginner's Corner
    Last Post: 03-25-2011, 04:30 PM
  5. Lube protocol for rear triangle pivot points?
    By C83L5oD in forum General Discussion
    Last Post: 03-24-2011, 10:18 PM
