Results 1 to 2 of 2
    Hissing Noise on Float RLC 130 (575)
    I have the 575 with all good stuff in it. Everytime I hit a bump or drop (big and small), I hear this hissing noise coming from the fork. Not sure if I'm setting the blow off threshold correctly located at the bottom right hand or maybe I'm missing something in the RLC set up. I have a Talas130 R in my SC and it's pretty quiet. Please advise. Thx.
    hissing noise
    The hissing noise you can hear is the damping fluid flowing through the shims / valves in the fork and is normal.
    If you back off all the rebound damping you will notice less hissing 'cause the damping is not working so hard.
    The more rebound damping you add, the more is will hiss, but this is not detremental in any way.
    Hope this helps.
