    Front Derailleur hits chainstay
    Had my Yeti 575 for over a year now - love it!
    When cleaning the frame I noticed a 'dent' in the upper surface of the chainstay from the cage of the FD hitting. I've adjusted the FD up a bit and now it is very noisy in the smaller two front rings with the chain rattling over the FD cage.
    Anyone have the same problem? Solutions??
    Richard
    Reputation: Dogboy's Avatar
    Quote Originally Posted by Rumblefish
    Richard
    This has been covered in several past threads. Your chain will only be noisy when you aren't on it - the suspension compresses and the derailleur drops away from the chain.
    Thanks for the heads up - i will do a proper search.
    However my chain definitely does rattle over the FD cage when I am riding and the suspension is compressed.
    Richard
    Are you by any chance using a 42 tooth chainring?
    If so, this could be a possible expaination.
    Chaser
