Results 1 to 10 of 10
    Reputation: Atomik Carbon's Avatar
    Fox 36-140mm or RS PIke 140 ??
    I have the choice of installing a Fox 36 or RS Pike , both in 140mm configurations. The weights are very similar and I am getting them at the same price. Which would you choose and why ?? This will be on a SB95C.
    Dec 2013
    I have experience with the 13 Fox 34 140 and 14 RS Pike RCT3 SA but not really any on the Fox 36, however I can't imagine it getting any better in a 140mm travel fork then what I have with the RS Pike on the front.
    13 SB95c/XT/EnveAM CK/RF NextSL/PikeRCT3SA/CCDBAcs/KS Lev
    15 ASRc/RS-1 120mm/EnveM60/RF NextSL/XTR 1x10 1UP
    That FOX 36 looks MASSIVE. I have only heard great things about the PIKE. I am getting either for $650...from what I heard the PIKE is better at slower speeds and the FOX at big hits and higher speeds....
    I've had a Pike for 6 month, great fork. I got a killer deal on Fox 36 & I've been on that for about a month. The Fox 36 is a slightly better fork. It just does everything better with exception of climbing as the Fox doesn't have the easy switch on top & the Fox is slightly more difficult to take the wheel off.
    Thanks. I have decided that the FOX 36 is just too much fork and since I am trying my darn best to spec light but strong components, I will go with the RS Pike. I spent a lot of money today on the Race Face Next SL crank set with direct drive chain ring and I do not want to add back the weight I just spent so much money to remove.
    The FOX 36 is a great fork, but I would only use its suiper DH capability maybe once or twice a year when I travel out West. Why carry all of that extra weight for 2% of the riding conditions ??
    Feb 2015
    Quote Originally Posted by Atomik Carbon View Post
    Atomik - How do you like the Pike on the SB95? I'm trying to decide between the fox 36 and the Pike for mine. I can get the pike slightly cheaper, but I've heard the 36 is an amazing fork at only a slight weight penalty.
    Anyone else who has experience on the 29er pike or 36 please chime in. I'm looking at either 140 or 150 forks. I pedal up to have fun on the way down so I'm slightly biased toward DH performance. I also ride fairly aggressively if that changes the feedback.
    May 2010
    Depends on your weight terrain and how you ride. For me at 250 riding PNW tech the pike is way too flexy. Don't sleep on X-Fusion the HLR damper tops either Fox or RS in my experience.
    36 is stiffer and has much better mid stroke support. What I used to think of as plush with the Pike I would now describe as wallow. It is a subtle, but significant difference. The 36 is also much more adjustable.
    Mar 2013
    I've heard that the Axle to Crown on the 150 Pike is the same as the 140 Fox 34, so I went with the 150 Pike on my SB95c. IDK if thats the same case with the 36.
    Aren't you in Florida? There is no way (from what I know of FL riding) you would really need either fork. The 36 would be massive overkill if you're more worried about weight. The Pike is good, rides high in the stroke and has a pretty respectable weight. Hell, I'd consider an even-lighter option from RS like the SID RCT3 that's even lighter. Or if you like to spend a lot of money, the RS1.
  1. RockShox Pike or Revelation at 140mm?
    By jazzanova in forum All Mountain
    Last Post: 3 Weeks Ago, 05:57 PM
  2. Lower 160mm pike to 140mm?
    By SHAHEEB in forum Shocks and Suspension
    Last Post: 08-18-2014, 07:40 PM
  3. Solo with 140mm pike and DBair CS
    By Esben in forum Santa Cruz
    Last Post: 08-28-2013, 02:33 PM
  4. 140mm or 150mm Pike to Remedy 29?
    By jaakkoso in forum Trek
    Last Post: 07-31-2013, 02:20 AM
  5. Replies: 8
    Last Post: 05-06-2013, 05:37 PM
