    Fork options for a 575? Or should I Push it?
    I have a Fox Vanilla 32 on my 575 and the is the weakest point on the ride IMO-(blows through travel. bottoms out etc with the heaviest spring installed). Sag is set correctly
    2010 575 with a Fox Vanilla 32
    1 1/8 non-tapered headtube
    Best part is that the bike remained basically unridden until I purchased it in May. I guess the guy wanted a pretty bike to hang up in his garage?
    I am having troubles finding an economical fork option with a 1 1/8 straight steer tube. I notice that Push Industries can upgrade the fork to an RLC giving me compression options.
    Any other advice or other forks that might work well? I just can't see spending $600+ for a fork on a bike this old.
    Matt
    On my 575 (2009) I started with a 32 Talas 140. That along with the RP23 went to PUSH. Once back, the bike was transformed, both front and rear.
    I have since changed the fork out to a 2011 Lyrik solo air set at 160mm. I have never looked back. It has the dh damper in it. No need for PUSH on this one.
    Hope this helps,
    Mike
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Running lyrik as well went from 2010 coil to 2013 rc2dh solo air. You can find the coil's pretty cheap.
    Bender to AZDog: I'm not the best person to give advice on not riding!
    Reputation: yeti575inCA's Avatar
    Dec 2011
    i ran a fox 36 160 rc2 on mine and transformed the 575..check Craigslist..
  1. Options for rear shock tune/rebuild other than Push?
    By Stahr_Nut in forum Shocks and Suspension
    Last Post: 09-06-2013, 06:47 AM
  2. Chain tensioner - push up or push down?
    By bank5 in forum Singlespeed
    Last Post: 06-25-2013, 10:42 AM
  3. Other than Push,
    By Cycle64 in forum Shocks and Suspension
    Last Post: 12-21-2012, 06:10 AM
  4. Push/Push vs Push/Pull
    By phlegm in forum Specialized
    Last Post: 12-20-2012, 08:36 PM
  5. Replies: 10
    Last Post: 11-13-2012, 12:34 PM
