• 10-26-2012
    bear
    I'm not sure I have a favorite yet, I need to try some more tires first. Certainly going through rear tires fast enough.
    Specifically I want to try the Hans D at least as a front - to see how it compares to the Rampage at least - and I'm still hoping for a more burly 2.2 to 2.3 rear tire.
    If I were serious about racing I'd definitely have two wheelsets though, one setup with 2.2" tires for racing (like the Ikon) and one setup with mo-sturdy-phat tires for daily driving.
    Best rear tire so far has to go to the Ikon 3c/eXc/EXO though - commensurate endurance with everything else I have used but a ton lighter and rolls super fast. Only thing is I didn't get to check it out under wet conditions, and it gives up a "little" to big-rock work because of lower volume.
    If I was riding strictly dry conditions (like Austin) I'd seriously be thinking about the Ardent 2.4 on both ends, great volume, solid sidewall, relatively fast tire. For me up here in the great wetter NE I'm not sure it's the right choice. I may try "the ardent" thing next spring after the area dries out though.
    but like I said, too many more tries to try. Schwalbe, Specialized, Hutchinson (is there a Python 2.3 29er - if it has a good sidewall it could be a great tire?), etc.
  • 10-26-2012
    CWnSWCO
    My favorite combo on Austin's dry, rocky trails has been the Panaracer Rampage (2.35) in front and Maxxis Ardent (2.25) in back.
    I used Schwalbes for the first two sets (double Ralphs, followed by double Nobby Nics). I thought they were good but didn't have any durability/staying power.
    I might try an Ikon instead of an Ardent in the back next... I'm curious about it.
    I've been really impressed with the durability of the Rampage... it looks almost like it did 500 miles ago.
  • 10-31-2012
    icelt
    No surprise here I understand, but got my rear XR400 trued back up almost 2 weeks ago. Now two relaitvely tame recreation rides and a single10 mile race later... noticeably out of true again. :madman:
    I'll be doing my BT review here in a little while probably and at this point I've got to dock at least 1 star from value no thanks to these effn soft DT rims and am considering knocking off a star overall as well. :( Sucks as the rest of the bike/build I love.
    Thanks for the Central Tejas tire notes addATX, gonna remember this for the Dallas Metro area come tire replacement time. Although thus far the Ikon's have working pretty damn well on everything save dusty soft dirt and loose rabble. But since 90%+ of the trails are other man do they roll well and fast on the vast majority of what I ride on.
  • 10-31-2012
    Huntro
    I wanted to jump on the bandwagon of XR400 hate also. After 50miles they were wayyyyyy out of true. It was bad! But then I had a wheel builder I trust go back over them, retention and true, and they've been solid since. I'm a clyde (220lbs) so I'm pretty hard on wheels.
    Try running the Ikon at 28 PSI or there abouts. I find it rocks loose and loose over hard pack conditions here in SoCal.
    EDIT: 11/16/12
    I would like to retract the above statement. I just bent my front xr400 rim beyond repair on a steep rocky decent. I chose a poor line, by the rim should have held up... Went OTB when the wheel wedged between the fork.
    Back on the xr400 bandwagon of hate. YO YETI! THESE RIMS DONT BELONG ON THE SB95!!!
  • 11-28-2012
    Huntro
    Beefy!
  • 12-11-2012
    50calray
    Hello,
    I just picked up an SB95, originally was shooting for a SB66 but decided to give the 29er a try.
    Anyhow, I have read mixed reviews on the wheel sets. My concerns is how well the wheel sets will hold up under my weight which is 273lbs. I'm loosing weight but not fast enough. So I'm looking into options as what to do. Should I have a local shop check the tension on the spokes or would my time be better spent looking for new wheels?
    If it must be new wheels, what would be a good affordable alternative? Something that is a direct bolt in replacement so to say.
  • 12-11-2012
    Mr Bacon Jr
    I would just have the shop put a set of Stan's Flow rims on the existing hubs. Not too expensive, and bomb proof. Then sell the DT rims.
  • 12-11-2012
    50calray
    Thanks, I'm going to look into it tomorrow!
  • 12-13-2012
    50calray
    Well after 10 miles my front wheel needs trued :sad:
    I'm waiting on a call from the LBS on what it will cost to swap in some Stan's and when they have time.
  • 12-14-2012
    CWnSWCO
    Yep... Those XR400s are a joke on that bike. Trashed mine in about 20 miles, I think.
    The XM490 s have been better.
    But, I may end up with Stan's next time too.
  • 12-17-2012
    Vampir
    What are you guys doing that is thrashing the XR400's?
    I've only had one problem with mine and that was my own fault. I got a broomstick sized piece of wood caught in my rear spokes on a steep downhill. It bent a bunch of spokes and the rim partially taco'ed on me. Otherwise, I've put ~1500 miles on them now without a problem at all. In fact, they've stayed remarkably true in that time.
    Point of reference, I'm mostly XC'ing with them and I'm about 165 lbs right now.
  • 12-17-2012
    50calray
    Well, in fairness, I out weigh you by 100lbs. I'm sure the XR400 are nice wheels but their not designed to handle my weight an abuse.
    Anyhow, I order a set of Stan's Flow EX wheels.
  • 12-17-2012
    bear
    Vampir, when I got my SB I weighed about 225, now I'm about 200.
    My riding conditions feature a ton of rocks and logs (NE PA) and often "at speed" - there's one memorable downhill I hit in Bald Eagle State Forest near RB Winter State Park where after the ride I figured that I was doing 15-20 mph in a carved turn through a 100 yard rock garden (6"-12" rocks).
    I've also had the bike doing lightweight downhill at Burke Mtn in VT.
    I have no problem believing the rims were not designed for that. The fact that I made both wheels become 'less than happy' leads me to believe it was the wrong equipment for me to have.
    But the Flow rims have not much cared about what I've done on the bike. I have a minor hop in my rear wheel right now, but that happened because after burping some air at one point of a ride I was bombing another descent and hit a log hidden by scrub undergrowth - which I *almost* managed to hop over anyway ... got the front over it. Only way to defend against that is to slow down, and who wants to do that?
  • 12-17-2012
    69erEverything
    The XR400 rim is a race rim much like the Stan's Olympic rim. Narrow and light weight with aluminum that dents easily.
    Companies spec them to drop the weight of the bike. They are high quality and price as well. Plus OEM deals are made long in advance. Fully built bikes are not sold ala carte ya know.
    Know what you are riding on and modify to suit your needs. It is part of the fun of mountain biking.
  • 01-21-2013
    icelt
    Welp it seems my personal ordeal with the XR400 rim is likely to be soon coming to a close. After a protracted discussion with the Yeti warranty department, which produced exactly zero options for resolving the problem... well unless, "customizing your own bike to better suit your personal needs can be a fun part of the sport" (ie thanks for the $3,600 and if the wheels we selected are causing you problems feel free to buy new wheels!) is considered reasonable problem solving, DT Swiss has offered the option to relace the wheels with their XM 490 rim for a reasonable cost.
    However I have not found much rider feedback on XM 490 and wanted to see if you guys had any useful experience? In general it is a significantly wider, deeper and heavier rim compared to the XR400, which I'd assume should bode well from the durability perspective:
    XM 490
    XR 400
  • 01-21-2013
    69erEverything
    Yes the XM series are very nice. Just rebuild the wheels already....
  • 01-22-2013
    icelt
    Thanks for the feedback.
    And that's exactly what I've been hoping to do, just took awhile to get to the point where someone, DT Swiss is this case, was presenting a reasonable solution. Still quite dissatisfied with Yeti's warranty department.
  • 01-22-2013
    CWnSWCO
    Sounds like we had similar conversations with both Yeti and DT Swiss.
    I've had much better luck with the XM490 than I did with the XR400. (DT Swiss was fair when helping me out with the replacement as well - good company).
    I wouldn't call the XM490 perfect, but they are much, much more durable than what Yeti spec'd!
  • 01-22-2013
    Mr Bacon Jr
    FWIW- just put a Chinese carbon fiber rim on the rear of my Big Top. Much stiffer, significantly wider (23mm inner rim width) and 110 grams lighter than with the XR400. Only have about 30 miles thus far, but am pleased at this point. If it works as planned, I'll be replacing the front rim with one, and building a set of race wheel with DT 240 hubs.
  • 01-22-2013
    icelt
    @addATX - I'm comforted to hear you actually have some seat time on the 490's. Agreed that it's not the ideal solution in my mind, I'd probably be on Arch EX's if I could do it all over again, but just to know that the 490's are at least a much better match for the capabilities of the bike (and the conditions in Central & North Texas) helps put my mind at ease regarding the decision. So I do very much appreciate your input. :)
    Likewise I have been pleasantly surprised by the general helpful attitude of DT Swiss. They seem to very much understand the intrinsic value of quality customer service and from the very first email I received from their service department they were suggesting potential solutions. Good company indeed. :thumbsup:
    Do you mind me asking how specifically you managed the shipping back to DT Swiss? I was thinking of asking for assistance from the LBS, if nothing else than getting some appropriately sized boxes, but is there anything else from your experience that you'd note regarding shipping?
    @bacon - Interesting idea. However at this point I really need to limit the hit to my pocketbook and DT's solution is definitely a very economical one.
  • 01-22-2013
    CWnSWCO
    Originally Posted by icelt View Post
    @addATX -
    Nothing special. I found a box that fit them, and used a bunch of crumpled newspaper to fill in the extra space.
  • 01-22-2013
    50calray
    Originally Posted by Huntro View Post
    Beefy!
    Agreed!
    I installed a set of Stan's Flow EX wheels and haven't looked back. These wheels take a beating and ask for more!!
  • 01-22-2013
    icelt
    Very good and simple enough. Thanks for the feedback.
  • 02-03-2013
    rasputero
    Hello everyone.
    Ive found this forum searching info about the xr400 rims.Ive recently built a set of wheels using this rim and want to run into tubeless.I want to use stans tape and valve only (no rimstrip).Do you think it it possible using tubeless ready tires?
    Im using my bike for xc only.
    Thank you very much!
  • 02-03-2013
    bear
    If your tubeless-ready or UST tires that have a fairly tight bead I think it may work.
    I used stan's rubber strips in the ones I had with the stock non-tubeless Maxxis tires and the system worked really well, their beads are more loose than the UST/tubeless-ready stuff.
    You may need to add a couple layers if it's still too loose a fit though.
