Results 1 to 5 of 5
    DT Swiss 440 Disc Rear 12mm on ASX
    is this possible ?
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    If the hub is 12x135mm then yes you can get a 12mm to 10mm adapter. Atomlab sells one on their website for $35. If it's as 12x150mm then no, you can't use it on the AS-X
    what do you think of these for an asx? i have a chris king now, but i want more stiffness in the back, so i wanna go for bolt on system.
    http://www.chainreactioncycles.com/M...?ModelID=17387
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    the bolt-on pro 2 should work good IIRC....I used to run it on my 575 and now it's on my Salty...
    Jun 2005
    I've got a hope Pro 2 on my rear wheel. I had it converted to a 10mm through axle, so it bolts on really nice and tight.
    Before that I just had the stock XT rear hub, and I put a solid bolt on axle in that hub. That was a cheap option since the axle only cost like $20.
