DH9 / straight 8?
i'm in need of bearings for the floating disk brake mount. can anyone help me out that may have some extras? i'v got a 2001 but i'm sure anything after 2000 will be the same size. the guys at Go-Ride have the part #'s but can't find anyone that has them
'11 Jedi
'01 Rocket 88 Stage3
2008 Toyota FJ Cruiser
The seal on the old bearings should have a number on it that you can use to find a replacement bearing at a local bearing supply store. Or you can use these guys: http://www.thebikebench.com/cat_bearing.asp?CatID=2
I ordered a couple of bearings from them recently for the floating disc brake on a Chumba F4.
If you cant find the number, you can measure the bearings inner diameter, outer diameter and width to help find the right size
thank you. the guys from go-ride came through and i'm all good to go. hopfuly the new bearings will fix the crazy vibration i was getting
'11 Jedi
- You may not post replies
- You may not edit your posts
Forum Rules
