Results 1 to 11 of 11
    Vitamin Bike Added
    Reputation: MTBCanuck's Avatar
    Creaking and crackling from carbon rear triangle on 2010 yeti 575
    I think the title says it all. I can't find any cracks and I have pulled apart and lubricated the bottom bracket and checked everything I can but it seems like the creaking is induced during stress on the triangle during hard pedalling when the triangle is under stress from the drivetrain. My guess is the sound is generated where the carbon meets the aluminum but i could be wrong. How the heck do I rectify this issue? The constant racket has me at my wits end. Thankful for any help!
    Keep the rubber side down
    Jun 2010
    Maybe try removing the dropouts, cleaning them, applying blue loctite and torquing to spec? Check the yeti manual for specifics. Other possible culprits could be the seat/seatpost or the bolts on your crankset.
    Reputation: mtb_tico's Avatar
    From my experience, also check your:
    - chainring bolts
    - Rear cassette fastener
    - Rear derailleur mounting bolt
    - pedal bearings (old Crank Bros especially).
    I've experienced significant creaking from all of these places/components. I have a 2011 575.
    snickers driven
    Reputation: MTB ABQ's Avatar
    My bet is the dropouts- try that first.
    Cleavage Of The Tetons
    Or the rubber baby buggy bumpers
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Vitamin Bike Added
    I am embarrassed to ask but how would I service the actual dropouts? Pull the aluminum from the carbon seat stay then put it back in? I looked at them and it is a press fit and not sure i would assemble or disassemble. Not sure the yeti manual covers that level of maintenance but could be wrong.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Re: Creaking and crackling from carbon rear triangle on 2010 yeti 575
    Quote Originally Posted by MTBCanuck View Post
    Simply remove the rear hanger and clean it and the dropouts. Apply a light coat of grease on the hanger interface with the drop out and use some blue loctite on the screws.
    DO NOT pull any aluminum anything from any carbon anything... Lol.
    +1 on "DO NOT pull any aluminum anything from any carbon anything... Lol. "
    Since you have a 2010, I believe you only have a QR derailleur hanger. It is held on by two small fastners. Looks like OS STANDARD QR HANGER WITH FASTENERS - 575 - Parts.
    The newer 575s came with two dropouts - therefore another story.
    Be sure to check what I mentioned above.
    Jan 2009
    Had a similar issue on my ASR5C and checked all of the previously mentioned suggestions without any luck. It turned out to be the shock bushings that were worn out resulting in a significant play causing it to creek when pedalling.
    Schipperkes are cool.
    Reputation: banks's Avatar
    make sure to grease the main pivot bearings that sit against the seat tube
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    I was having a similar problem with my 2010. Ended up being as easy as tightening up the rear QR. Wish I had figured it out before I bought a new bottom bracket and pedals (thinking that they were the issue).
  1. Yeti ASR5 - 650b rear triangle?
    By mnigro in forum Yeti
    Last Post: 09-17-2013, 07:12 AM
  2. Replies: 30
    Last Post: 12-08-2011, 01:52 PM
  3. Replies: 1
    Last Post: 10-04-2011, 09:40 PM
  4. 2010 Superly 100 rear creaking issue
    By Olis1 in forum Gary Fisher
    Last Post: 09-09-2011, 06:48 AM
  5. Replies: 7
    Last Post: 07-05-2011, 08:01 PM
