Results 1 to 3 of 3
    Don't be a sheep
    Sep 2004
    Crankarm clearance on 2011 ASR-c
    Building up my ASR-c (2011 with the new all carbon rear) and the FSA K-force light cranks are really close to the chainstays, like 2mm on either side. Is this common?
    "Do not touch the trim"
    Jun 2010
    Had the same problem with gravity light cranks which are made by FSA as far as i know.
    Mine was on an sb66, it's the way the cranks bend as far as I could see no way round it bar new cranks which is what I had to do.
    I tried spacing bb everything too dicey so I gave up..
    I can't remember the measurment used for the bend in the crank but shimano has the best.
    Hope that helps
    Don't be a sheep
    Sep 2004
    Quote Originally Posted by moneycash View Post
    Hope that helps
    Thanks. that's kinda what I figured. It's hard to toss a $500.00 crankset but oh well. Thanks again.
  1. 2011 Yeti ASR7 clearance, $999 frameset
    By eurospek in forum Yeti
    Last Post: 12-29-2011, 12:43 PM
  2. Trek Cobia (2011) rear tire clearance
    By tedlove in forum Trek
    Last Post: 12-07-2011, 03:12 PM
  3. 2011 Casseroll Tire Clearance?
    By djw in forum Salsa
    Last Post: 05-18-2011, 01:34 PM
  4. 06 Vagrant crankarm clearance?
    By mb-3 in forum Transition Bikes
    Last Post: 03-02-2009, 06:39 PM
  5. crankarm puller removal from crankarm
    By krazcanuk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2004, 07:28 AM
