Results 1 to 3 of 3
    Reputation: gnarbar's Avatar
    Oct 2013
    Couple of 303 WC Questions
    Greetings tribe.....couple of quick questions.
    What type of grease is recommended for the 303 WC rail system?
    Any advice as to the correct spring rate for a rider who is about 215 lbs with gear? Various online rate calculators say between 350lb and 400lb due to the low leverage setup. Does this sound right? I'm going to order steel springs to start with to get the rate correct, then go for Ti once I have it set up right. Looking for a fairly grippy ride that goes more to the traction side of things than mad pop for jumps, but a bit of a lively feel wouldn't go amiss if I can mix that with good traction.
    Any advice would be very much appreciated.
    303 WC
    I Like Bicycles
    Reputation: Thimk's Avatar
    Your probably better off to just contact Yeti directly. They're very good at getting back promptly.
    I was looking at the 303, but would up with an Aurum myself. FWIW, I'm 200 lbs. and the 350 lb. was way too light for me. I moved up to a 400 lb. You're either a 400 or 450.
    #1 Norco Aurum LE
    #2 Yeti SB-66
    #3 Evil Sovereign
    Oct 2013
    Quote Originally Posted by Thimk View Post
    Yes they are!
    - lithium grease
    303 WC
  1. A couple questions
    By motoman465 in forum Pennsylvania
    Last Post: 07-14-2012, 08:09 PM
  2. Couple of questions
    By mxz02 in forum All Mountain
    Last Post: 04-16-2012, 08:47 AM
  3. Couple of questions!!
    By Luigiugueto in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2011, 02:32 PM
  4. new here, couple questions
    By fivespeedsteed in forum General Discussion
    Last Post: 04-13-2011, 08:58 AM
  5. couple questions about RIP 9
    By nurseman in forum Niner Bikes
    Last Post: 03-06-2011, 11:34 PM
