Results 1 to 13 of 13
    trail "cleaner"
    Check those main Pivot Bearings!!!!
    575 owners..... If you're riding aggressive All mtn. trails, you might want to pop those main pivot bearings out and clean relube annually. I made the mistake and waited a little too long and now one has a 'notchy' feeling. Funny thing is.... all the bearings within the 'dog bone' are all spinnin' freely. I took them apart anyway (removed the dust covers) and cleaned /regreased them. Thought I might as well redo the whole suspension while the shock is out getting 'Pushed'. Glad to have a back-up 575 for times like this. I never miss a ride opportunity
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Good tip... I will take a look in a couple of months.. mine is barely broken in yet
    However, at least the main pivot bearings are easily accessible, for the dogbone disassembly, did you use Yeti's tool or some other DIY one?
    Reputation: garnetspur's Avatar
    May 2005
    Main Pivot Bearings Frozen
    my main pivot bearings were frozen out of the box...brand spakin' new frame.
    i had a ridiculously annoying vibration coming from the rear. looked into to everything that could have been causing it. got a tip about the main pivot bearings being pushed in too far. well, we took them out, and they were frozen.
    luckily, no damage seemed to be done to the frame..
    so yeah...check those suckers.
    trail "cleaner"
    bought the tool from Yeti
    Quote Originally Posted by crisillo
    Makes removal of the dogbone bearings quick and easy. Too bad I couldn't figure out how to use the thing for the main pivot bearings removal though.
    Beer
    Reputation: Endo King's Avatar
    Sep 2004
    New question here.
    I am getting a bad creaking on my ASR-SL, which seems to be worse when tension is on the pedals like when climbing. I suspect it is from the main pivot bearings. Apon inpecting them I found out that one of them is very gritty and not very smooth. I have went over everyhting else on the bike, that could be leading to the creak. Could somebody verify if I am right here? So then the next question, is how do you remove and replace these bearings? Or do I have to have a bike shop take care of it for me?
    Hi!!!
    Reputation: BelaySlave's Avatar
    Earlier this year my bike was creaking and cracking like crazy. Took my baby to Custom Cycles here in Boise, ID and the pivot berings were gritty. They were relubed and that thing was quiet on the next ride out.
    Idaho Biking Yahoo! Group
    Support these shops: www.CustomMtnCycles.com & Reed's Cycle
    Reputation: JustMtnB44's Avatar
    My 575 has been smooth and quiet so far in my two years of northeast riding where I hose the bike off every other ride. However, I am going to disassemble everything this winter to check bearings and possibly get shock PUSH'ed. I think it could also use a thoughout cleaning and inspection for damage, and I need to install some new parts (custom chainguide anyone?). Thanks for the tip though.
    garnetspur, what do you mean the bearings were frozen? If they didn't turn at all then the suspension wouldn't really be able to move I would think?
    trail "cleaner"
    more likely the pivot itself........
    Quote Originally Posted by Endo King
    The main pivot if loose AT ALL will create the most obnoxious creak when hammering along. Now, WRT your bearing removal...I did a search on this forum and found this AS-X main pivot bearings
    It's an ASX frame but you'll get the idea.
    Sep 2004
    Quote Originally Posted by AZmtncycler
    Good advise, but how do you take the dustcover off to relube? and what kind of grease do you use?
    My main's are notchy and I would love to add some grease to see if that helps
    thanks marc
    You can remove the dust covers with a thin screwdriver (like the ones used for jewelry of watches) you don't need much force or twisting to do it. I prefer to use thicker grease like Rock & Roll for bearings. I haven't repacked the bearings on my 575, but had done it on my old Epic... easy to do and makes quite a difference, even when they feel a little notchy. One more thing, as long as the races seem fine (no deformation) usually jew grease and cleaning will make them run like new...
    Cheers,
    Cris
    Beer
    Sep 2004
    Thanks for the info!!!
    mutaullyassuredsuffering
    Reputation: used2Bhard's Avatar
    Dec 2005
    Asrsl
    Mine creaked out of the box. The pivot was frozen from the factory (no lube). After two annoying days, It went to a shop, and the problem was fixed. All my pivots loosen and the creak comes back monthly. One quick bout with the torque wrench and it is gone.
    Beer
    Sep 2004
    Quote Originally Posted by used2Bhard
    Well I just got my ASR back in May, and I did a seson of racing on it this past summer, which included a few rainy races, and lots of creak crossings. And it seems like it didn't take long for my creaking to start. Maybe they were defective from the start like yours. My 575 has seen 2 years of riding in all kind of conditions, wet and dry, and it has held up.
