    Oct 2012
    cable routing for a 07 yeti 575
    Just curious if anyone has phots of their cable routing?
    Im building my first yeti 575 from scratch and had nothing to follow for routing cables and housing. also the small cable guide on the bottom of the frame which way does it install, it has a long side and short side but seams to fit either way.
    Look here > http://yeticycles.com/pdf/manuals/07OwnersManual575.pdf
    It should have all the information you need.
    Mike
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    If that little black cable guild for the front der. is put on backwards the cable will eat into the frame....then you'll know it's on backwards, lol.
    Oct 2012
    thanks guys both answers helped alot..
