Results 1 to 28 of 28
    Reputation: garnetspur's Avatar
    May 2005
    Build My 575 for me!
    ok. i'm taking the next step soon, very soon. i know these threads are started weekly...but, i want/need your suggestions on builds for my future 575. first off, it's been proven that orange bikes are the fastest, so i'm getting the orange frame. with the all important cosmetics out of the way...build the rest for me starting from the enduro package (i.e. swapping forks, wheelsets are the most important for me):
    a little background on me. i'm a hardtail guy. my main ride is a IF Steel Deluxe. other main bike is an Ibis Alibi (aluminum hardtail). but, i'm going to the other extreme with 5+ inches as my first FS bike.
    i want to start with the Enduro Package pricepoint and keep the price around there first and foremost by improving the fork and the wheelset. i want it to be more of an all mtn build. i.e. doesn't have to be the lightest build at all. just the best ride for the money is what i'm looking for.
    thanks for the input.
    Jun 2005
    I can predict the future:
    1 person (iviguy) is going to tell you about the RS Revolution, and that you should buy it from Will at Full Cycles
    3 people will tell you to replace the seatpost clamp, because it sucks donkey balls (it does, listen to them)
    those same 3 will tell you to also get a thomson seatpost along w/ the new clamp.
    The bike rules, no matter if you're rockin' a fox or an RS or a 'zokes or whatever.
    In my mind, I can do it!
    Reputation: iviguy's Avatar
    Quote Originally Posted by lacticacidbath
    Don't listen to laticacidbath. He really can't predict anything.
    I will recommend putting a RS Revelation on that bike though. I would definately not recommend the "Revolution" as was predicted. I hear that fork is crappy...
    Since he already told you to replace the seatpost clamp, I won't tell you that because although I believe it is a good move I don't want to be party to his predictions....
    He didn't predict anything on the wheelset soooo... Definately upgrade the wheelset. If Gary at fullcycles.com will give you $200 credit on the current wheels, spend another $300 on top of that and get the CrossMax enduro wheels.
    Lastly, either get some really paddes shorts or replace that saddle because it hurts your hinney.
    Now, I predict that lacticacidbath will indeed post a reply to someone on this board. This will in fact happen today. Yes, I am that good...
    Reputation: flipnidaho's Avatar
    Dude...
    a new Viz machine!
    order it local from Reeds unless you can do your own wrenching then go online.
    Like everyone will say, the Fox Talas I had on mine was unreliable and within 6 months:
    1. seals were useless from Day 1
    2. Lockout knob ball bearings malfunctioned (although this was the fault of a shop in Moab who was trying to fix my seals).
    3. Rebound rod broke
    I had the Talas Pushed and put on a Revelation in the meantime and the Pushed Talas and the Revelation are about the same performance wise... If Reeds will trade the Talas with a Pike or a Revelation, I'd go for it. YRMV
    Trade the seatpost clamp for a Salsa or Hope unit.
    Get some good foothills tires (I run a 2.35 Kenda BG Stick-E up front and a Mutano 2.4 in the back).
    Upgrade the wheels when you get the chance... Light wheels really transformed this bike for me (since I'm more of an XC guy).
    Jun 2005
    I disagree with the wheelset advice.
    The CrossMax are built with custom hubs and rims, so that if you were to break a spoke, or otherwise whack the wheel out, you'll have to be shopping around to fix'em. Plus, you need a special spoke wrench to get at the nipples, as they are down in the hub, not on the rim. People are wild about that wheelset, but I'd be wary. For the same amount of dough just swap out the rims.
    But, Mavic x317's are fine rims. (jeebus, especially for texas). If you have the money, and feel like you have to bling everything out on the bike, than maybe 317's arn't right for you. If you ride alot, and recognize that you may thrash your wheels, the 317's will be just fine, IMHO.
    May 2005
    i'm probably going to go the online route. i don't really need the LBS support from a wrenching standpoint, and eagle is quite a drive. i'll drive out to see brian for wheels, etc.. but that's about it. actually, i like to get brian to help me with things. he doesn't give youa run around on things, always follows up and treats you fair. and he's good with bikes. but, we don't need to turn this into an anti LBS thread.
    bottom line though; i doubt they could come close with the price, tax, etc. from what i've read, there are quite a few online guys that offer great support during the order and thereafter.
    as far as wheels go. i want a traditional wheelset, not a system wheelset. i have a set of crossmax xls and they are great. fortunatley, brian in boise mentioned above is very good with wheels and helped me out with my crossmax front. anyway, i want a traditional 32-hole build. if i get the pike with the thru axle...what are my options for hubs...not breaking the bank here...again, starting with the enduro build kit.
    which pike should i get? what model. the revelation is air only right? i'm not worried too much about the weight..so, i want a coil.
    Quote Originally Posted by garnetspur
    If online, really, I know I sound like a broken record here, but fullcycles.com is excellent. The prices are better than anywhere I have found.
    If you are wanting to upgrade the wheels, why not just get the Race disk build that comes with the DT Swiss wheelset? You can get either the QR or the Maxel option plus you get upgraded components. And going from the Float RLC to say a Pike coil is actually money in your pocket. The Fox will probably give a trade in value of about $600 to $650 and the Pike coil shouldn't be more than about $400 to $450. You can get the baseline race disk for around $2700 with about a minus $200 for the fork swap and that puts you in the $2500 range. Add $100 if you want the DHX Air. This is the route I would go.
    Well, the rims themselves may be ok. I'm not impressed with the hubs nor the spokes. I think this wheel build has some noticeable flex too. But what do you expect for a $200 wheelset?
    Jun 2005
    I'll buy those wheels off you for $125, as they're used.
    Interested? You can keep the cassette, rotors, and the qr's.
    LOL.. Actually only one is used and the other is brand new.. (a replacement is being delivered today for the rear). But rather than spend more right now, I'll just keep them until they are thrashed. My wife is limiting my spending after this purchase...
    Reputation: Joeboater's Avatar
    Oct 2003
    Experiment
    If you are not going LBS and you want to try out different combinations, check out wrenchscience.com . You can put together different builds on their site. They put together a very good product.
    May 2005
    just got off the phone with full cycles
    haven't pulled the trigger quite yet...
    but, it's invevitable...it's going to happen
    he's quoted me an awesome price with some switching out of the fork from the vanilla to the Pike-Coil. and switching the wheels at no extra charge from the 317 to the 321.
    his recommendation was that the 317's were not soooo hot...and the 321 would be a better AM rim..
    this also comes with the new RP23 shock.
    here's a little review i found through google.
    Have now done 4 rides with the new Fox RP23 rear shock and I am impressed. The earlier RP3 had a lever that put it in either open or pro-pedal mode, but the RP23 has that and then 3 individual settings for the pro-pedal mode, light, medium and stiff. settings. In the stiff setting, it is almost a lockout, but the shock still actuates on a hit.
    i don't know much about it...but, as long as it does the job and has more function.. cool, right?
    here's more:
    The new Fox RP23 shock The Fox RP3 shock was well received, but some users didn't like the rather vague clicks and were confused by the three settings. The RP23 shock is coming out to simplify and improve things. Firstly, there are only two positions for the lever (That'll be the '2' in the name then) - these are 'Firm' Pro Pedal and 'Light'. Then there's a three way knob to turn (that's the '3' then') - this dials in the Pro-Pedal setting when in the 'firm' setting.
    So this means that in 'Light', there's very little ProPedal. In 'Firm' it can be set to your choice of 'Light, Medium or Firm' depending on your preferences, weight and the trail. The platform in all positions only affects low speed force (pedalling bob) and doesn't affect your medium and big hit damping.
    Talking of damping, the RP23 also has an increased rebound damping range that should cover every situation...
    sounds good/fine to me...
    moving on..the quoted price is 2350ish...just need to postpone..a touch longer...and then, i'll make the order....
    also...i'm a boise resident now..but, i'm originally from SC...so, i'm a gamecock fan..i had to ask if he was keeping up with the beavers run in the College World Series..he said he wasn't really watching..but, that Corvallis was pretty excited about it..
    anyway, i mentioned that as a gamecock fan....i've always wanted to see a matchup with the cocks and the beavers...the innuendo game if you will.....he got a kick out of that..and said they were always hoping for the same....
    btw..cocks would win...
    Reputation: mtbike_AK's Avatar
    Quote Originally Posted by iviguy
    What makes the CrossMax Enduro Wheels so special? (Not trying to be a smart aleck, just trying to see what the the hype is..??
    May 2005
    Broke out the Plastic!
    ordered today from Full Cycles.
    should be in my possession next week sometime!
    i'll post pics for sure.
    here's more:
    You will really like the RP23. But in case you don't... I will gladly trade you for my RP3...
    Congrats! I'm glad Will is getting some business. He really works with you before, durring and after the sale.
    Post pics when you get them.
    Who is John Galt?
    Reputation: Big Jim Mac's Avatar
    They got my business too. If we were thinking we could have got together and said, "Now, what if I buy 10 of these???"
    What, me hurry?
    I have my eye on another set of wheels.. If I wind up buying them at a good price, I may take you up on this offer... Interested? The odds are probably less than 50% though unless the price is right on what I am looking at. So don't hold your breath....
    Jun 2005
    I just got a more used pair of x317 discs for $100. handbuilt.
    they're to replace the x223's that I killed. good luck on the new wheels though.
    Dude...
    Reputation: Jessep's Avatar
    RS pike... Doooo it Stiff as hell, and light enough
    Ride on
    Congrats on the new 575! I feel obligated to share my experiences with the stock wheelset. The rims have actually been very reliable. However the Deore rear hub doesn't feel right and is a pain to service.
    I snapped one of my spokes on the rear wheel a couple of days ago. I found out that the stock spokes are only 15 gauge at the ends, and since they are double butted they are even narrower in the middle. The guy at my LBS thought they were too narrow for a disc wheel and I agree with him.
    I would look for a wheelset with sealed cartridge bearings and 14/15 double butted spokes.
    May 2005
    Update!
    still waiting on my 575 to arrive. but, the guys at full cycles are treating me great over it. just one of those things that is necessarily their fault.
    first, they were waiting for my '07 enduro kit to come in.
    then, the latest has been with my Pike coil fork. i wanted the moss gray color and i didn't want the poplock thingy. we've learned a lot in the last day or so about what RS offers aftermarket..
    well to get the 426 model with no poplock..RS only offers the silver color. to get the moss gray, you have to get the 454.
    so, i'm stuck with a black 426 coil with poplock....and i'll probably take the poplock off down the road.
    soooo, i'm heading up through washington state at the end of the week, and then back over through idaho...maybe over to montana..and then back down to boise...it's all up in the air really.
    i'll be doing all of this without my brand new 575 which i hope my neighbor drags into my house.
    sucks...but, i'm being patient with this...too many stresses in life to get worked up.
    it's kinda fun...almost like christmas as a kid again...
    however, if there are any more holdups...i may begin to get angry..
    i'll report with pics,etc...as soon as i get it..
    Who is John Galt?
    I'm rethinking this buying over the internet thing. My bike arrived and I was totally on my own putting it together. Had I paid the extra bucks to get it from the LBS (and any shop can get you a Yeti) they would have put it together, tested it, set the shock up for my weight, worked out the bar/stem height and made sure everything worked. As it is, I have the bike and the shifting sucks, the bike showed up without skewers and I still don't have them and I am going to have to go to the LBS and pay them to make the drive train right. I'm still money ahead, but when you spend this kind of money you should have someone behind you to take care of problems.
    What, me hurry?
    Oct 2003
    Internet
    Wrenchscience sent me my bike all set up. Pressures were right on and for the little construction I had to do, pieces of tape showed positioning. Even the seat height and fore/aft positioning was right on the money.
    Quote Originally Posted by Big Jim Mac
    Yep, and that is the obvious trade off. Fortunately my bike had all the parts and wasn't a big deal to put together. Shifted great and aside from having to do the shock setup myself there wasn't anything else that was really a big deal. I kind of enjoyed putting it together actually.
    For me, the closest LBS that sells Yeti is about an hour away which is really inconvenient for small issues. Taking the money savings was a better deal. But for some, you are right. It may be better to take a hit on the money but have an LBS standing behind the sale.
    May 2005
    full cycles
    is building my bike for me. then, they will disassemble the necessary parts (stem, bar, seatpost, wheels, etc...package it up and ship it.
    it should be ready for tweaking with shock and fork within 30 minutes or less.
    i was expecting to have to build it myself, completely. this is a time saver and mean i'll be on the bike faster.
    as for the one guy with the shifting problem. it just takes a little practice to get good at setting up your derailleurs, etc...the sram or shimano website (depeding on your parts) should have ok ,manuals to follow. it's not that hard once you start messing with it...
    however, a work stand, or a good tree branch definately makes it easier...
    oh yeah..i figure i am saving a lot by ordering from full cycles...and the only shop that carries yeti in boise is about 25-30 minutes (traffic) free from downtown boise where i live. lastly, i just don't like dealing with the LBS.
    Hi!!!
    Reputation: BelaySlave's Avatar
    Congrats on the new 575 garnetspur! Let's see...that makes you, me, Gary and Sara Jo, impdude...who else?
    Idaho Biking Yahoo! Group
    Support these shops: www.CustomMtnCycles.com & Reed's Cycle
    May 2005
    belay..if i ever get it!?!?!
    btw...i got the orange frame. i love orange bikes. sorry to steal some of your orange yeti thunder man. we need to get together for a ride sometime.
