Results 1 to 11 of 11
    Reputation: Thiago7's Avatar
    Jun 2010
    brake adaptors for yeti SB66 and Fox float 160 ??
    Hi.
    I just ordered an Sb66 and Fox float 36 RLC 160. Im going to use a set of Shimano XT brakes with 203mm front and 180mm rear. What brake adaptors do I need.
    Thanks in advance.
    Momentum is your friend.
    Reputation: dvo1's Avatar
    Post mount 180 and 203 models.
    Reputation: barenal's Avatar
    Quote Originally Posted by dvo1 View Post
    Is this what's needed for the 180 rear?
    Amazon.com: Shimano SM-MAR180 Rear Post Mount Adapter 180mm I.S./I.S.: Sports & Outdoors
    Jun 2010
    Quote Originally Posted by barenal View Post
    Im not sure thats the right one but the one I bought is different.
    Ill have to wait until tomorrow when I get the frame.
    Reputation: Dogboy's Avatar
    Nope, that's an IS mount. The SB66 uses a post mount. Like this:
    or this:
    Jun 2010
    The one I bought was the wrong one
    Thanks for the help guys. Now I know what to get.
    Jun 2010
    Quote Originally Posted by Dogboy View Post
    or this:
    I just want to make sure I understood this?
    Do I have to a mount that is designed for the front to use it on the rear wheel??
    Im fine with that if it works...
    Quote Originally Posted by Thiago7 View Post
    yes, post-mount is post-mount whether it's on the front or rear. So the adapters are interchangeable.
    Long live the ASR-7
    Reputation: Doba's Avatar
    Nov 2008
    Perfect example of why I take my bike to the shop for these types of things. I've ordered so much wrong crap that would have been done correctly the first time at the LBS.
    Reputation: kondi's Avatar
    For rear 180 rotors on my Sb66 which of the following adaptors I have to buy ?
    First:
    Second:
    or It does not matter, because both are good ?
    Reputation: adamkob32's Avatar
    Oct 2012
    I used the first design to mount a 180mm on the rear of mine. Either will work though, just orients the caliper in a bit of a different position then the other,
