    Bottom bracket spacers on SB-95a
    My bike has no spacers between the bottom bracket cups and frame. Per Shimano's instructions, an XT crank with 73mm BB shell width (mine measured 73.6mm with the ISCG spline cover) should have one 2.5mm spacer on the drive side. Is there a reason I don't have the spacer or is this an unintentional oversight?
    Spring! Spring! Spring!
    Reputation: bear's Avatar
    Assembly error?
    Mine is the Race build. Just wanted compare notes with other owners to see if they had noticed the same thing.
    Mine was '12 model year Rave and had the spacer. Still does.
  1. XT bottom bracket spacers on Blur LTc
    By Wheeldog in forum Santa Cruz
    Last Post: 08-17-2013, 10:10 AM
  2. Bottom bracket spacers
    By dreednya in forum Ibis
    Last Post: 04-26-2012, 10:38 PM
  3. Bottom bracket spacers
    Last Post: 04-26-2012, 06:49 AM
  4. spacers for a Hive bottom bracket
    By campykid in forum Fat Bikes
    Last Post: 12-20-2011, 05:01 AM
  5. How many bottom bracket spacers?
    By Skybo053 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2011, 09:27 AM
