Results 1 to 8 of 8
    Reputation: azbeersnob's Avatar
    Bigtop - hole in rear triangle
    Curious if anyone else has had a similar issue with the rear triangle?
    Jeff
    Ka-coo-ka-cha!
    Reputation: snigs's Avatar
    Feb 2010
    Nope. But judging by the removal of the lettering and the surrounding collateral damage, it looks like the tire has been rubbing the frame for a long time. How large of a tire are you using? Brand and model?
    For reference I run a 2.25 RaRa, TL, on a Stan's Arch and have had no issues outside minor rub due to a tweaked wheel and some abrasion and chipping there due to junk flying off the tire, but it was easily protected with some 3M car wrap.
    Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
    I have been running 2.2 Ardents on Stans Arch rims for quite a while now and have a good 1/2" clearance.
    Jeff
    reading comprehension wat
    Reputation: dv8xin's Avatar
    Mar 2013
    Some duck tape should fix it. Quack quack! JK JK!
    I believe that once carbon fibers are broken, that entire strand becomes dead weight. I'm no carbon expert, but I believe that carbon's strength is in its tensile strength, so it's typically aligned so loads attempt to pull/stretch the fibers. If there's a break or a wrinkle, the surrounding carbon fiber and underlying plies are left to handle the load. In other words, are you experiencing flex, err, I mean "compliance" in areas you're not used to? Ghost shifting under high torque or lateral loads?
    If my understanding of carbon is correct, and my assumption is correct that Yeti used long lengths of carbon, laying it up from dropout, wrapping around to the other dropout, then you'd have a swath of carbon, about as tall as that hole, that is about as useful as a piece of duct tape, in terms of stiffness and strength, binding the carbon above and below it to maintain structural integrity.
    Do you get a lot of dead brush and other trail debris jammed in that area or something?
    I like to jump to conclusions, oversimplify, gossip, and participate in popularity polls.
    Reputation: smithcreek's Avatar
    Nov 2012
    How is the rear triangle joined to the front? Bolted? Bonded? Is it easily replaceable or replaceable at all? I've just been wondering since this is a frame I'm considering.
    Reputation: drbelleville's Avatar
    Have you heard back from Yeti? If you are looking for repair if replacement is not possible, you can check out Calfee, they were going to do a fork for me, yet the Aluminum Drop-out was bent and as such would have been too much hassle to repair. Appleman also does repairs, and I think you may be able to look around here on MTBR as the topic has been covered over with the roadies.
    Home | Calfee Design
    Carbon Fiber Frame Repair | Appleman Bicycles
    Finally got in touch with Yeti and had my LBS ship the frame back. Got word from Matt at Yeti that it is covered and a new frame is on the way.
    Obviously, I could not be happier with Yeti's customer service...thanks guys.
    Jeff
    OK...all better now
  1. Does anybody else have this rear triangle?
    By mikkosan in forum Turner
    Last Post: 03-09-2012, 11:41 AM
  2. sb rear triangle help
    By iridetitus in forum Titus
    Last Post: 01-01-2012, 10:47 AM
  3. Rear Wheel Not Centered in Rear Triangle-EMD
    By mtnbikej in forum Niner Bikes
    Last Post: 12-20-2011, 02:42 PM
  4. Replies: 7
    Last Post: 07-05-2011, 08:01 PM
  5. FSR rear triangle
    By nodnelson in forum Specialized
    Last Post: 05-30-2011, 07:26 AM
