Results 1 to 3 of 3
Thread: Asx weight?
    Asx weight?
    How much does an Asx with a 6" weigh? What about in the 7" position?
    Also how is the pedaling?
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Yeti says:
    "Frame Weight (Med size): 9.1 lbs Coil Shock/8.1 lbs Air Shock"
    http://www.yeticycles.com/Bikes/BikesASX.cfm
    The Small must be slightly lighter and the Large must be a bit heavier.
    How much travel you have in the rear does not change the weight: it is all the same parts but one part is fixed in a different place.
    The total weight depends on what parts you use. My AS-X pedals just fine. I feel the weight over my hard tail bike but, on the other hand, it is easier to pedal when the terrain is rough.
    Some different AS-Xs, some of them mention the weight.
    http://www.yetifan.com/as-x.html
    Reputation: goRz's Avatar
    May 2005
    Mine is 40 lbs with Boxxer Ride, DHX coil, fairly light tires (800g each)
    Passion beyond reason!
