Results 1 to 12 of 12
    Reputation: jet fixer's Avatar
    Feb 2006
    ASX headset question
    What headsets are you using on your ASX's ?
    I'm concerned with reducer shims to use a 1 1/8 headset has anyone had any problems with this set-up?
    I have also been looking at the FSA orbit-extreme ProR
    its just that my other four bikes have king and I like staying with what I know.
    I'm considering buying ASX and I would like to use King headset. I'm wondering if this headset will work http://www.chrisking.com/headsets/hds_devo.html ?
    Feb 2006
    I know that will not work the headtube on an ASX is 1.5 that headset is for a 1.25 headtube most modern mt bikes are 1.125 headtubes
    just for reference:
    1.5 = 1 1/2 inch
    1.25 = 1 1/4 inch
    1.125 = 1 1/8 inch
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    If you want to use the AS-X (onepointfive head tube) with a 1 1/8 fork, you need either a special headset that allows this or a reducer that lets you put in a 1 1/8 headset.
    I have a Cane Creek Double X going into my AS-X but they also have a 1.5 to 1.125 version:
    http://www.canecreek.com/double_x_flush.html
    Reputation: Dogboy's Avatar
    My experience is that the FSA Orbit Xtreme 1.5r is the highest quality reducing headset out there.
    Reputation: desmo's Avatar
    Fsa
    For 1.25 steer tube forks, I recommend a FSA Orbit Xtreme Pro 1.5 to 1.25 headset. After a winter of apocalyptic rain and mud the headset is as smooth as the day it was installed.
    shaved yeti
    Reputation: bonkey's Avatar
    I agree. Go orbit.
    I've run the cane creak XX. It is a XC headset designed for Cannondale type bikes. If you get one (and you're a beater), you'll either unseat the bearing race or unseat the crown race from your fork.
    Also run the PIG 1.5. Nice Cheap, Hard to keep clean.
    Also ran a reducer set with a pig dh. The only thing wrong with a reducer set is that it takes a gorilla to press one of those bad boys in. No problems with it though.....
    Too old to ride. Too young to die.
    What forks have 1.5 steer tube?
    1.5 steertube forks
    I know Manitou has the the Travis in a 1.5, there could be more models with 1.5 steer tube.
    Feb 2006
    Thanks guys,
    Just ordered a FSA I can not justify a king at the $125 they are now charging when the FSA has a ten year warranty and sealed cartridge bearings for $80. The Blue king would have looked sweet though.
    Don't use reducers in the ASX!
    Beware! Yeti do not recommend the use of reducers in the ASX.
    I was recommended to use Cane Creek by the UK importer.
    Cheers.
    Chaser.
    Mar 2006
    does marzocchi have any forks with a 1.5 steer tube?
