Thread: ASX 6 to 7
    ASX 6 to 7
    Do I really need the tool from yeti to switch out the dogbone from 7in to 6inch or is
    there another way around it?
    Sep 2004
    Quote Originally Posted by Doro
    No, you don't. Metric hex driver or universal bike tool will be OK.
    how do you get the bushing out then? I can unscrew one side but the bushing stays in and I cant get it out!
    Stray Bullet
    Reputation: Nagaredama's Avatar
    There really isn't a bushing holding it in. Just the bolts that screw together. Use a small allen wrench to push the female bolt out.
    You only need the tool to remove the bearing on the shuttle.
