I decided to review my shock setup and baseline it again. Checking the manual from Yeti, they recommended 2 "turns" of HSC, but that doesn't seem right as that's full adjustment. I'm assuming they mean 2 "clicks"
Anyone run into this before? Wanting to compare some other serious. Mine is as follows. I forget what pressure I'm running in the boost valve but I'll double check that later when I can find my pump.
Asr7 setup
600# spring (235# geared up)
Rebound-8 clicks
Bottom out-1 turn
LSC-10 clicks
HSC-2 clicks
