• 11-20-2012
    KrisRayner
    ASR7 with dual crown (40 or boxxer), Ride reports?
    I've been contemplating a Van 36 180 for my 7 for shuttle runs. However I've noticed that the axle to crown height for a 180 fork and a 203 dual crown, like a Fox 40, is only a 5mm difference. Drop the 40 by .5" and it's mute point.
    For those that have run a 40 on there 7, any problems you've run into? With the A-C height being so close I can't see it really being a problem for frame strength. Handling changes?
  • 11-20-2012
    drbelleville
    Man I have never seen one (ASR-7) setup like that, I know for your shuttle runs, you may not be worried about any weight, but the Fox Van is a great fork, and saves you that extra pound of the 40. Not to mention the extra overall bulk of the 40.
    I would'nt knock it if some one did it, just seems a bit overkill to me. But hey there is always a first time for anything.
  • 11-20-2012
    zebrahum
    I'd run your idea past the people at Yeti before you try it. Dual crown forks tend to exert a larger force on headtubes than an equivalent A-C single crown fork. They'll pretty obviously say that it'll void your warranty but they might tell you if the frame is suitable for a dual crown fork or not.
  • 11-20-2012
    socalMX
    I have seen a dual crown on many other AM frames, Nomad specifically. Honestly a single crown 180 coil like the Van or even a Totem would prove to be much more playfull and still plow!
  • 11-20-2012
    eatdrinkride
    I've seen d/c forks on the old style 575. This was 5,6, 7 or 8 years ago so they probably weren't 180mm forks. This doesn't answer the question but....
  • 11-21-2012
    zebrahum
    Bear Grylls drinks his own piss; doesn't mean it's a good idea... if you catch my drift.
  • 11-21-2012
    KrisRayner
    Here's the picture that got me going on the whole thing.
  • 11-21-2012
    Joules
    I don't have a 7, but I have a Canfield One with a Boxxer, which seems like a similar bike: long travel trail/"all mountain" whatever that means.
    I have the Boxxer WC, which is an air fork, and I gather not what you were thinking, but it's lighter than a Totem or 66, and as you noticed has about the same axle crown. I'm very happy with it, even though it's never been on a lift or shuttle (IOW I climb with it). There's only one place I've ever really noticed the limited wheel/bar turning, and that was easy to get around once I got used to it. I do need to think about my line a little farther down the trail than I was used to doing, but that's not a bad thing; I've probably gotten faster because of it.
    I don't regret it at all, for what that's worth.
  • 12-07-2012
    2FUELS
    I've been thinking about this as well, i.e. Fox 40 @ 7" travel to balance out the ride. My 7 see's nothing but FR now, (i'm ditching the reverb to). I found the braking bumps/DH courses at Trestle put the Fox 160 well beyond its limit
  • 06-25-2013
    KrisRayner
    Well this is what happens after a couple slow days at work and browsing craigslist too much. I found a Boxxer for $200 in decent shape. About to find out how it does. Attachment 811016
  • 06-25-2013
    swan3609
    I had a boxxer that I was getting ready to lower to 7" and throw on my 7, but a 303 fell into my hands and I built that up instead. My 7 will get built with a boxxer someday.
    And there is a 7 with a 40 on the front of it in the 7 build thread if I remember correctly.
    Send from my phablet.
  • 06-26-2013
    KrisRayner
    First ride finished with the boxxer fork. Definitely feel the weight on the climbs and the now super slack seat tube angle. I'm sure I could adjust to it, but the 160 is definitely ideal for climbing. The comes to life in a while different way on the descents, and that was with minimal tuning of the fork. Definetly worth throwing on the front for lift service. Although the bottom bracket is a little high at around 14" I didn't notice any negative handling from the bike, but a more sensitive and experienced rider might.
    All it all it wasn't a bad experiment. I might want to try riding one if the new
    Talas forks to see how it feels against my buttery Van 160. If its as good ad they say, I might be selling both forks for a new Talas 180.
