Results 1 to 5 of 5
    ASR5 worth the money to go thru axle?
    Posted this in the ASR5 build thread but no responses.
    Has anyone converted their asr5 from qr to thru axle? Is it worth the $80 for the conversion - did you notice significant added stiffness?
    Thanks for the help.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: ASR5 worth the money to go thru axle?
    I felt there was a slight difference. Depends on what wheel too though. If you have a noodly wheel to start with, you may not notice any diff.
    Sent from (redacted by nsa)
    a Chris King turquoise 142 thru axle sounds like an answer for me
    Thanks DD. After adding up the cost for the TA end caps, Shimano 12x142 axle and chip set its looking to be about $105.
    I have a Spank Oozy laced to XT hub but they were laced up by a great builder and are stiff wheels. At least on par with my Flows on Hopes which is what would go on there for the conversion.
    Sounds like it may not be worth the cost for a small bit of added stiffness.
    Reputation: BobGolden's Avatar
    "may not be worth the cost"
    If I thought like that I would be riding my old steel Jamis Dakota/8SpLX....instead of my ASR5/XO/Easton Haven C...
  1. Oakley worth the money?
    By cr500taco in forum Apparel and Protection
    Last Post: 01-01-2014, 07:12 PM
  2. is the Niner Emd 9 worth the Money???
    By subarumtbjrk in forum 29er Bikes
    Last Post: 01-30-2013, 08:55 PM
  3. Is it worth the money?
    By yellowzx in forum Wheels and Tires
    Last Post: 12-26-2012, 05:53 PM
  4. Forks worth the money?
    By DanC7 in forum Beginner's Corner
    Last Post: 05-31-2011, 02:05 PM
  5. Worth the extra money?
    By Mountaineer204 in forum Beginner's Corner
    Last Post: 03-29-2011, 02:25 PM
